degreased motor,...now i got a problem
Old May 26, 2003 | 10:18 AM
IWearMyKswiss's Avatar
New User
Default degreased motor,...now i got a problem
so i degrease the motor 2 days ago,..right after i degreased the motor i had to run to walmart,...im cruising about 35 mph when all of a sudden my speedo goes down to zero...im like WTF???,...so then i hit a small pothole in the road and my speedo starts working again,...then periodically it goes back down to zero...most of the times i hit a bump it would start working again,...and sometimes without hitting a bump it starts working again,...oh and the speedo works fine everytime i turn the car off and then back on,..but 15 mins of driving and then it goes down to zero,...anyone ever encounter this problem?? any info would be appreciated,...TIA
Old May 26, 2003 | 10:20 AM
tonesdef's Avatar
Default Re: degreased motor,...now i got a problem (WiDeBoDyEK)
You proably knocked lose the sensor on your trans i have done it befor. Just look for your trans and a push the plug back in and it should be fine.
Old May 26, 2003 | 10:41 AM
Archidictus's Avatar
Unceasing Measure
Default Re: degreased motor,...now i got a problem (tonesdef)
VSS (vehicle speed sensors) go bad all the time on our precious Hondas. They're easy to jar loose and quite fragile. You should check and make sure that it's dry, unbroken and plugged all the way in before doing anything drastic, but I'd start putting some cash aside just in case. Don't think they're that expensive, but it never hurts to be prepared.
Old May 26, 2003 | 11:12 AM
EH339's Avatar
In degreasing your motor, did you get your speedo sensor wet? While going through a deep winter puddle many many years ago, I lost the use of my speedo sensor for a few days until it dried out. A couple of years after that, my speedo sensor died and the socket was corroded. So the sensor and plug was replaced.
Old May 26, 2003 | 11:28 AM
New User
Default Re: degreased motor,...now i got a problem (94RedSiGal)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94RedSiGal &raquo;</TD></TR><TR><TD CLASS="quote">In degreasing your motor, did you get your speedo sensor wet? While going through a deep winter puddle many many years ago, I lost the use of my speedo sensor for a few days until it dried out. A couple of years after that, my speedo sensor died and the socket was corroded. So the sensor and plug was replaced. </TD></TR></TABLE>
how much was a new sensor and plug??? its been about 2 days since i degreased it,...i was thinking the same thing about letting it dry out but i forgot about that after i let my car sit for a day and a half and it still did it
Old May 26, 2003 | 11:31 AM
Infamous_Imports's Avatar
This happened to me in my car, except when i hit the brakes everything turned off (radio, gauges etc.) Come to find out there was a loose ground in my fuse box + it was a little corroded. Tightened it up and everything started working fine again. No problems since.
Old May 26, 2003 | 11:34 AM
sappsycho's Avatar
Default Re: (Infamous_Imports)
I found the sensor online at $105. I don't know if this is the best price?
blacc_ej1
Oct 14, 2009 01:49 AM
gsrbeast
Jul 28, 2006 06:34 PM
turboman
Mar 13, 2006 02:19 PM
rerun07
Dec 8, 2005 08:21 AM
Andy M
Apr 29, 2003 12:24 PM
