h22 injectors
Hey i got a quick question i just picked up from a friend some 370cc rc injectors but will they work with my h22 since i have the injector resistor box....they are obd1 injectors?
the 370 rc's i have i think arent peak and hold i believe u can tell because where the injector clip slide in theres a little groove on peak and hold injectors and on regluar there isnt?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Carnut »</TD></TR><TR><TD CLASS="quote">werent the OBD1 injectors peak and hold and that is why they usethe resistor box....as opposed to OBDII which were Saturated switch injectors.....if you have an OBD I engine and ECU it shoudln't matter, right
WEll the resistor box is used to lower the voltage.
</TD></TR></TABLE>WEll the resistor box is used to lower the voltage.
e jay one
Aug 6, 2005 02:48 PM
