Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Fixing a tire leak used for lapping
Old May 26, 2003 | 08:17 AM
markpaco's Avatar
Default Fixing a tire leak used for lapping
I have a slow leak in one of my tires. It is pretty slow but I suspect that I have a nail in it. In the past, I used those tire plugs that you stab into the tire. I learned that this was not a good idea when my steel belts tore from the inside during a lapping day. So what options other than buying a new tire do I have for repairing this tire that I occasionally use for lapping?
Old May 26, 2003 | 08:20 AM
.RJ's Avatar
.RJ
Default Re: Fixing a tire leak used for lapping (markpaco)
I plugged a falken tire last year and had no problems with it at all.
Old May 26, 2003 | 09:30 AM
Vinny Chase's Avatar
Default Re: Fixing a tire leak used for lapping (.RJ)
just go to discont tire, they fix that ish for free
Old May 26, 2003 | 10:00 AM
philstireservice's Avatar
never plug a tire ...especially something speed rated...........
if you must, use a patch plug ...a good tire shop will repair it correctly........but for safety sake you shouldn't do any sort of speed event on a tire that has been repaired......
Old May 26, 2003 | 10:03 AM
.RJ's Avatar
.RJ
Default Re: Fixing a tire leak used for lapping (Maxx44)
it was repaired at a tire shop. cost me $25
it was a patch, not a plug (sorry)
Old May 26, 2003 | 10:09 AM
743power's Avatar
NASA won't let you on the track if they know you're tire has been repaired. I have a patched tire, and it's held up fine for over 2000 miles of driving in the last 2 weeks, but I wouldnt go on track with these tires anyway. . .
Old May 26, 2003 | 11:16 AM
Knestis's Avatar
Default Re: Fixing a tire leak used for lapping (743)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 743 &raquo;</TD></TR><TR><TD CLASS="quote">NASA won't let you on the track if they know you're tire has been repaired...</TD></TR></TABLE>
We have run all kinds of patched and/or plugged tires on racing cars - including GY and other racing slicks. This seems a little extreme, since trackside tire service people have been repairing tread-punctured tires for ages.
Kirk
Old May 28, 2003 | 10:58 PM
jdm_eg6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">I plugged a falken tire last year and had no problems with it at all.</TD></TR></TABLE>
i second that... i had two different tires repaired. both had nails... bothe led up fine on the track.
Old May 29, 2003 | 05:26 AM
XR4racer's Avatar
patch-plug... race proven on my part.
Old May 29, 2003 | 06:16 AM
electronspeeder's Avatar
Me too, no problems.
Old May 29, 2003 | 07:44 AM
Tyson's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 743 &raquo;</TD></TR><TR><TD CLASS="quote">NASA won't let you on the track if they know you're tire has been repaired. </TD></TR></TABLE>
is that even in their CCR?
Old May 29, 2003 | 02:43 PM
Grumpy's Avatar
New User
11.4.2 Wheels and Tires.
The general condition of the tire and wheel assembly must be good. There shall be no cracks or other damage to the wheel. There shall be no cords, bubbles, or other visible damage on the tire. All lug nuts must be present and tightly hold the tire and wheel assembly to the car’s hub. No hubcaps or beauty rings are allowed. Imitation “knock-offs” must be removed.
18.3 Tires
Tire grooving is not permitted in classes with “spec” tires. All drivers competing in classes that require “spec” tires must purchase their tires from the specified vendor. Call the local NASA office to find out which vendor is required.
Old May 29, 2003 | 03:52 PM
APEX CRX's Avatar
I've run yoko a032's that have at least a few patches and never had a prob. as long as the shop does it right
citrus3000psi
May 26, 2008 08:29 PM
accordinglyevil
May 2, 2008 12:00 PM
Drag'nGT
Sep 30, 2005 07:40 AM
illusion
Sep 5, 2002 08:14 AM
gsr94
Jun 24, 2002 03:41 PM
