Some New Pictures of My ITR Header
Old May 26, 2003 | 08:13 AM
SMSP's Avatar
Default Some New Pictures of My ITR Header
The following is my latest version of the ITR header. I was able to delete one bend from tube #3 and increase the bend radius of 4 others, since bigger bend radii promote better flow characteristics. Ground clearance was also improved by about 1/4", but I don't feel that it can be any better or else the #2 and #3 tubes will be touching the oil pan. Plus, like I said before, there's only so much room between the oil pan sump and the tranny/block bracket to accommodate 4 large primary tubes.
I test fitted these primaries on a 92-95 Civic 4dr with a B18 swap and I was able to install them (although they were tight going in) without removing the A/C fan or clutch cylinder which was required for my last version. And no mods are required to the tranny/block support as was the case in the previous versions.
pic deleted
The small bolt (second bolt hole from the right) will need to be removed for clearance of the 3/4 merge.
pics delete
Sorry for not using a high tech camera for these pictures.
Modified by SMSP at 12:39 AM 8/7/2003
Old May 26, 2003 | 08:26 AM
sslude's Avatar
Default Re: Some New Pictures of My ITR Header (SMSP)
looks nice..hope everything works out
Old May 26, 2003 | 08:30 AM
Mires's Avatar
Hey Dave, I was wondering if in fact this header will bolt up to a stock ITR? Hooked up to a custom cat of course. Also, would you recommend your header even if only doing i/h/e? On a stock ITR will a V-AFC help the #'s any? Sorry for all the questions but I have a stock ITR and I only want to do i/h/e. I want the best curve possible so I figured why not get the best.
Thanks Dave
euclid's Avatar
Default Re: Some New Pictures of My ITR Header (sslude)
are you producing these yet, or are they special order only? thanks
Old May 26, 2003 | 09:10 AM
Smitdog's Avatar
Default Re: Some New Pictures of My ITR Header (euclid)
Something always Improving! Dave as always....
Old May 26, 2003 | 10:11 AM
io_burn's Avatar
New User
Default Re: Some New Pictures of My ITR Header (Mires)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mires &raquo;</TD></TR><TR><TD CLASS="quote">Hey Dave, I was wondering if in fact this header will bolt up to a stock ITR? Hooked up to a custom cat of course. Also, would you recommend your header even if only doing i/h/e? On a stock ITR will a V-AFC help the #'s any? Sorry for all the questions but I have a stock ITR and I only want to do i/h/e. I want the best curve possible so I figured why not get the best.
Thanks Dave </TD></TR></TABLE>
I'm wondering the same. Also, have you come up with any kind of pricing yet on the new header? Around a grand I'm guessing like all the other high-end headers?
Old May 26, 2003 | 10:26 AM
sleeprhatch's Avatar
I wish you lived next door to me lol Looks great I will someday be a SMSP owner!!
Old May 26, 2003 | 10:48 AM
Padawan's Avatar
Darth ModerVader
Good packaging Dave. Will the new header incorporate the "X-tube" secondaries seen in another thread, or are they still strictly experimental and/or optional? The impression I had from reading the other thread was that the secondaries performed well in comparison to your traditional versions. Either way, keep up the excellent work.
Old May 26, 2003 | 06:03 PM
SMSP's Avatar
Default Re: Some New Pictures of My ITR Header (Padawan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote">Good packaging Dave. Will the new header incorporate the "X-tube" secondaries seen in another thread, or are they still strictly experimental and/or optional? The impression I had from reading the other thread was that the secondaries performed well in comparison to your traditional versions. Either way, keep up the excellent work. </TD></TR></TABLE>
Testing isn't completed on the Xover secondaries. Not sure if the folks would be willing to pay for the extra labor to build these secondaries for a street application. There are an additional 6 butt welds and the Xover weld plus all that fit up work.
Old May 26, 2003 | 06:39 PM
NSX Bob's Avatar
New User
Looks good, Dave. Like I told you before, I'll be purchasing one to match the exhaust sometime in the next decade .
Old May 26, 2003 | 06:51 PM
OutLaw MR's Avatar
nice work
Old May 26, 2003 | 07:11 PM
Lamchop0000's Avatar
what happend to the bottom half of that engine block?
Old May 26, 2003 | 08:34 PM
White Dragon's Avatar
Hi Dave,
I have several questions:
1. Will your new ITR header clear/fit in conjunction with a Fluidyne Radiator and stock cooling fans?
2. How does your full system (header, cat, and muffler) compare in performance with that of a full JDM ( 2 1/2" collector) Mugen set-up?
3. Do you guarantee any minimum amount of perfomance gains?
4. How long from the receipt of order would it take to get a complete system?
5. How much is your complete system?
6. Can you post pictures of your exhaust (muffler) system?
7. How does it compare as far as noise to the Mugen twin loop?
Sorry for all of the questions, but I am very interested. Thanks.
Old May 26, 2003 | 08:41 PM
ScaleExtric's Avatar
Default Re: Some New Pictures of My ITR Header (Smitdog)
whoa! Now thats a header
Old May 26, 2003 | 09:13 PM
b18cu's Avatar
Default Re: Some New Pictures of My ITR Header (ScaleExtric)
will that header rattle against the oil pan? looks kinda close??
Old May 26, 2003 | 10:55 PM
onyx00's Avatar
Default Re: Some New Pictures of My ITR Header (b18cu)
Eh, I'll just wait for Comptech to copy the design j/k
Very nice work.
Old Jun 3, 2003 | 02:12 PM
Default Re: Some New Pictures of My ITR Header (White Dragon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by White Dragon &raquo;</TD></TR><TR><TD CLASS="quote">Hi Dave,
Sorry for all of the questions, but I am very interested. Thanks.</TD></TR></TABLE>
I am still waiting for a response.
Old Jun 3, 2003 | 03:15 PM
Kamil's Avatar
I guess it will not fit if someone has a bigger than stock oil pan? Like the Moroso.
Oh well, can't make 'am all happy.
Old Jun 3, 2003 | 03:16 PM
MattD@Stoptech's Avatar
I am still waiting for a response.</TD></TR></TABLE>
Did you try emailing Dave personally?
Old Jun 3, 2003 | 03:18 PM
.RJ's Avatar
.RJ
Default Re: Some New Pictures of My ITR Header (El Pollo Diablo v3.5)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by El Pollo Diablo v3.5 &raquo;</TD></TR><TR><TD CLASS="quote">
Did you try emailing Dave personally? </TD></TR></TABLE>
or *gasp* picking up the phone?
Old Jun 3, 2003 | 05:53 PM
Tweakmeister's Avatar
Default Re: Some New Pictures of My ITR Header (.RJ)
there's a few people who'd like to know
Old Jun 3, 2003 | 06:05 PM
TodaSi's Avatar
Default Re: Some New Pictures of My ITR Header (Tweakmeister)
Tiight
Old Jun 3, 2003 | 06:50 PM
done's Avatar
Thats very nice....
Old Jun 3, 2003 | 06:53 PM
py1188's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tweakmeister &raquo;</TD></TR><TR><TD CLASS="quote">there's a few people who'd like to know </TD></TR></TABLE>
Yeah I'd like to see the info posted as well
Old Jun 3, 2003 | 07:56 PM
SMSP's Avatar
1. Don't know, but I'll get you a dimension of how far the ubes stick out from the manifold gasket surface.
2. I haven't done a direct comparison between the 2, but the testing I've done or that I've seen of my 4-2-1 against the Mugen or DC JDM, my has a better torque curve.
3. As for the cat back, I think my system flows better than the Mugen TL since the tubing is a full 2-1/2" OD from B pie flange to tip, where the Mugen is at (2) different sizes which are both smaller, plus my system doesn't have the 2 tight radius bends like the TL, but again no direct comparison has been made. My old 2-1/2" system was on a car that supported over 230 whp.
4. The new header will be built from 100% stainless steel, including the flanges. The flanges take about 4 weeks to get from the CNC shop and then I plan to do a run of at least 10 ITR headers which should take 6-7 weeks. I'm presently getting the cat back tubing mandrel bent and then will need to get all the resonators custom built ( I think this could be done in the same period of time). I'm going to try something different on the above header for the secondaries in order to simplify the first section of the cat back system. I hope to test this set up on the 14th.
5. I haven't finalized the price on the new 100% stainless ITR header since I have to wait for the results from the 14th for teh final design. What I can tell you is my new H22 100% stainless header that will go into production within a couple of weeks came in at $1175. IF the ITR header came in at that price that would only be a $200 difference from my current ceramic coated mild steel header.
6. Custom resonators: https://honda-tech.com/zerothread?id=450813
Installed system: https://honda-tech.com/zerothread?id=469853, the muffler used in this system will be ceramic coated silver or painted black. I'm looking into having it built out of polished stainless steel.
My header, 93506 cat and cat back audio clip: https://honda-tech.com/zerothread?id=519681, If the system is too quiet you could always remove the smaller resonator and replace it with a section of 2-1/2" tubing.
7. Again, no direct comparison just the sound clip.
Sorry for not answering these before.
