How much boost are you SOHC guys running on your blue box (Greddy kit)?
Old May 25, 2003 | 06:24 PM
boostincoupe's Avatar
From: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
Default How much boost are you SOHC guys running on your blue box (Greddy kit)?
How much can stock injectors handle? 7 psi? 8 psi? Also, can RC 310cc injectors (the ones that came with the Si kit) handle 10 psi?
Old May 27, 2003 | 07:45 PM
Default Re: How much boost are you SOHC guys running on your blue box (Greddy kit)? (fnananon)
bump
Old May 28, 2003 | 07:35 AM
boostsohfast's Avatar
Default Re: How much boost are you SOHC guys running on your blue box (fnananon)
I ran mine at 7 psi with stock injectors, stock fuel pressure, stock timing, and a Walbro 255 pump. No pinging or anything and it ran great. I would think with the blue box and 310cc injectors you would be able to run 10 psi, maybe have to delay the timing a touch. I just ditched the blue box yesterday and I'm running the afc hack now at 10 psi and lovin it.
Old May 28, 2003 | 07:46 AM
Default Re: How much boost are you SOHC guys running on your blue box (boostsohfast)
Thank you! Finally an answer from someone who's actually run that setup. That's exactly how I've been planning to run mine, stock injectors w/ a 255lph pump at stock timing. Should I get my fuel injectors cleaned and tested, or do you think they'll be okay as is? Also, I have a B&M commandflo FPR, and it's set at 41psi at idle, what should it be set at when the greddy kit goes on?
Old May 28, 2003 | 07:51 AM
glagola1's Avatar
I know that the blue box will support up to 7psi with 310 injectors and a good deal of retarded timing but after that you run out of fuel. 310's and 10psi is not a good idea. The pulse width of the injector becomes too high. Hell, at 15psi my 440's are at 77%... yikes.
Old May 28, 2003 | 09:02 AM
autoEXturbo's Avatar
I ran the greddy kit on my d16y8 for awile. I ran it @ 8psi for alittle while on stock injectors, timing, and a 255lph intank pump. The motor held strong and when i swapped i gave it up. The other guy said the motor ran strong for him.
CivicRaping
Apr 13, 2005 02:58 PM
skierGT
Oct 8, 2003 10:49 AM
Eyetattoo
Sep 27, 2003 09:44 AM
skierGT
Jun 28, 2003 11:41 AM
CivicSoul
Oct 6, 2002 11:16 PM
