Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
rear swaybar concerns (torn subframes are bad. . . )
Old May 25, 2003 | 12:24 PM
743power's Avatar
Default rear swaybar concerns (torn subframes are bad. . . )
I'm in the process of a full susp. overhaul on my 94 cx. I have a 14mm gsr rear swaybar I want to install, but I've read way too many 22mm itr horror stories. I understand that the rate on the 14mm bar is drastically less than the 22mm one, but do I still have a chance of damaging the rear subframe without one of those reinforcement kits (bsq,beaks)? I have no front swaybar, and 12k front springs, 8k rear.
Old May 25, 2003 | 12:31 PM
SPiFF's Avatar
Default Re: rear swaybar concerns (743)
Tear out is most common when you run a really big bar with soft(er) springs which allow allow the car to roll a lot. Best thing to do is use higher rate liner springs and a bar which has a good mounting design.
Old May 25, 2003 | 01:16 PM
JV's Avatar
JV
Who?
I agree with what SPiFF says, but in your particular case i'd say getting one of the reinforcement kits would be a good preventative measure.
Plus it will be there if you ever move to a larger diameter bar like the ITR.
Old May 25, 2003 | 04:34 PM
SkyeC's Avatar
Boba Connoisseur
25 Year Member
I've talked to plenty of people running the 13mm / 14mm LS / GSR swaybar set-ups without SRKs that autox/etc and they have had no problems with their subframes. 22mm is a different story.
Old May 25, 2003 | 04:56 PM
SpiceyRice's Avatar
Default Re: rear swaybar concerns (SkyeC)
I've got a 92CX with the ITR bar and I would recommend using a bar with a subframe renforcement. I've seen the ITR attachment points, and comparing them to the CX is scary, the subframe attachment points are easily half as strong at the ITR, and I've seen plenty of subframe tears.
Heck I think even SPiFFs GSR has had a rear swaybar subframe problem with the previous owner.
I'm running the Beaks Kit and think it's a good design and high quality. I've seen people make their own, or buy a bar that comes with better attachment clamps. I wouldn't run a 22mm bar without one.
Old May 25, 2003 | 05:12 PM
89civicdx's Avatar
Default Re: rear swaybar concerns (SpiceyRice)
I run a 22 itr bar on the rear of my 89 civ and have never had it tear out with any spring rate from 300-900. Aslong as you use plates to spread the load under the "D" bracket and on the other side of the cross member(so it doesn't pull or tear out) you will be fine.So yes you have to reinforce it but if you mount it properly and sandwich the crossmember with some sort of reinforcement...it shouldn't matter what rate you use.
VarTheVar
Suspension & Brakes
15
Apr 27, 2018 02:36 PM
Spawne32
Suspension & Brakes
18
Apr 21, 2010 06:33 AM
lumnite
21
Mar 3, 2008 02:19 PM
Team Bukkake Sucks!!!
42
Jan 14, 2008 07:05 AM
deviant1
Aug 25, 2004 07:23 PM
