::B20 throttle body????::help if you can
Old May 25, 2003 | 11:39 AM
spock_rocker's Avatar
memoryFAB.com representative
Default ::B20 throttle body????::help if you can
will a B20B throttle body fit a D16y8 intake manifold?? if so what steps would need to be taken. thanxx for your help!!
Old May 25, 2003 | 11:42 AM
The Destroyer's Avatar
Default Re: ::B20 throttle body????::help if you can (spock_rocker)
Im not sure but most Bseries dont match up with the Dseries.
Old May 25, 2003 | 11:49 AM
eg6ajk's Avatar
yes it does work there should be no problem. if its the 99-00 JDM b20B (orthia) you might need to use it with the throttle bracket (it looks just like the gsr TB)
Old May 25, 2003 | 12:11 PM
Quik Chris's Avatar
Default Re: ::B20 throttle body????::help if you can (eg6ajk)
It fits, but the linkage bracket is 180° backwards from the B-series. Keep in mine the B20 Tbody is the same as the B18B's.
Old May 25, 2003 | 05:50 PM
Default Re: ::B20 throttle body????::help if you can (Quik Chris)
would it just be easier to get a B18 TB then. i just want something thats gonna move more air then stock but i cant really afford to buy a aftermarket one! thanxx for the imput
Old May 28, 2003 | 11:57 PM
J2turbo21's Avatar
What is the bore of a crv throttle body?
Old May 29, 2003 | 12:44 AM
Quik Chris's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spock_rocker &raquo;</TD></TR><TR><TD CLASS="quote">would it just be easier to get a B18 TB then. i just want something thats gonna move more air then stock but i cant really afford to buy a aftermarket one! thanxx for the imput </TD></TR></TABLE>
Not really. Those linkage brackets are pretty much on there, they're not coming off. It would be worth the wait for a BBK or equivilent T-body. Don't try some custom special that will be more hastle than it's worth. Imagine it like this, say you punch a hole in your doorknob directly at 12 o'clock. That's how the D-Series is. But the B-Series has it punched at the bottom. Then on top of that, it's not circle shaped.
VitaminB20
Jul 10, 2018 11:12 AM
Ray Satomi
Sep 30, 2017 05:24 AM
talkJDM
Nov 10, 2008 01:15 PM
b20powereDA
Mar 9, 2006 10:34 AM
Eggman
Jan 18, 2002 03:13 PM
