::B20 throttle body????::help if you can
memoryFAB.com representative
will a B20B throttle body fit a D16y8 intake manifold?? if so what steps would need to be taken. thanxx for your help!!
Re: ::B20 throttle body????::help if you can (spock_rocker)
yes it does work there should be no problem. if its the 99-00 JDM b20B (orthia) you might need to use it with the throttle bracket (it looks just like the gsr TB)
Re: ::B20 throttle body????::help if you can (eg6ajk)
It fits, but the linkage bracket is 180° backwards from the B-series. Keep in mine the B20 Tbody is the same as the B18B's.
Re: ::B20 throttle body????::help if you can (Quik Chris)
would it just be easier to get a B18 TB then. i just want something thats gonna move more air then stock but i cant really afford to buy a aftermarket one! thanxx for the imput
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spock_rocker »</TD></TR><TR><TD CLASS="quote">would it just be easier to get a B18 TB then. i just want something thats gonna move more air then stock but i cant really afford to buy a aftermarket one! thanxx for the imput </TD></TR></TABLE>
Not really. Those linkage brackets are pretty much on there, they're not coming off. It would be worth the wait for a BBK or equivilent T-body. Don't try some custom special that will be more hastle than it's worth. Imagine it like this, say you punch a hole in your doorknob directly at 12 o'clock. That's how the D-Series is. But the B-Series has it punched at the bottom. Then on top of that, it's not circle shaped.
