which axles and int. shaft
Old May 25, 2003 | 09:52 AM
b18crx's Avatar
Default which axles and int. shaft
I purchased a set of axles and shaft(ebay) which stated they were ''y1''. the axles seemed great, nothing wrong just by turned cvj before installing, until i put them on. the axles didnt last five mins. then i found some 90-93 teg axles and tehy didnt last either. whats the prob? the half shaft? selection of axles?
running an itr motor with 92-93 gsr ys1 teg tranny. do i use 92-93 gsr axles and shaft also? also using ats lsd. could it be this or dust caps?
Old May 25, 2003 | 12:11 PM
yaya's Avatar
Default Re: which axles and int. shaft (b18crx)
in what car?
Old May 25, 2003 | 02:03 PM
b18crx's Avatar
Default Re: which axles and int. shaft (yayaRl337)
thought username would give that one away....88 crx si
Old May 25, 2003 | 06:58 PM
b18crx's Avatar
ttt
Old May 25, 2003 | 07:19 PM
poison's Avatar
You will need to use 90-93 Integra Axles.
Old May 25, 2003 | 07:44 PM
b18crx's Avatar
Default Re: which axles and int. shaft (poison)
and int. shaft or keep the y1 i have now? and just keep going through axles?
Old May 25, 2003 | 07:56 PM
poison's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18crx &raquo;</TD></TR><TR><TD CLASS="quote">and int. shaft or keep the y1 i have now? and just keep going through axles?</TD></TR></TABLE>
Sorry bout that. Yes, also the Int shaft.
Old May 26, 2003 | 06:19 AM
b18crx's Avatar
thanks for the help. are all 90-93 int. shaft and axles the same? say i get all gsr(92-93) since im using the tranny? still the same and will work?
Old May 26, 2003 | 10:28 AM
Blaze45's Avatar
Brrraaaap!
90-93 teg axles and int. shaft too. Be glad you didnt start the swap w/o the int. shaft and want to kill yourself....
Blaze
Old May 26, 2003 | 04:26 PM
Newman's Avatar
New User
Default Re: which axles and int. shaft (Blaze45)
Uh, since you have a Y1 intermediate shaft, you need to use a SHORTER driver side axle, like the 86-89 Integra driver side axle. If you have a S1, J1, A1, YS1 intermediate shaft (shorter than the Y1), then you can the 90-93 Integra axle on the driver side. Passenger side is the same.... 90-93 Integra.
Old May 26, 2003 | 06:22 PM
b18crx's Avatar
Default Re: which axles and int. shaft (Newman)
thanks a million
im not sure of exactly which int shaft i have so ill just get another set from someone.
Old May 26, 2003 | 06:28 PM
b18crx's Avatar
9107 posts??? man.....
loudassVTEC
Sep 22, 2005 10:11 AM
twin rex's
Jun 27, 2004 07:58 AM
Eggman
Feb 8, 2002 10:45 AM
