clutch problem need help! experts opionion desperatly needed
Old May 24, 2003 | 08:26 PM
ls95hatch's Avatar
Default clutch problem need help! experts opionion desperatly needed
all of a sundden my clutch is all messed up. when i start the car cold it is like there is a loss of pressure or something and i cant put it in gear, after it warms up alittle bit i can jam it in gear but its hard to drive. after i ve been driving around for like 40 min or so there clutch will be close to back to normal. whats the deal? much clutch is a weak one, but it doesnt seem like its worn out yet. could someone help me?
Old May 24, 2003 | 08:50 PM
garagespecial
Guest
Posts: n/a
Default Re: clutch problem need help! experts opionion desperatly needed (ls95hatch)
try draining your clutch fluid and refill and bleed it...sometimes the little things make a world of difference
Old May 24, 2003 | 09:00 PM
gezer's Avatar
Default Re: clutch problem need help! experts opionion desperatly needed (garageSPECial)
is it a stock clutch or and aftermarket one?? and how many miles where put on it???
Old May 24, 2003 | 09:34 PM
boostedcivicsir's Avatar
Mr. Badwrench
if you rest your foot on the pedal does it sink? if so and this is common, it needs a master cylinder. look on the floor where the clutch goes through the firewall. is it wet? if so replace the mastercylinder. bleed accordingly.
legend97
Transmission & Drivetrain
Jul 6, 2017 07:45 AM
favd21
Sep 8, 2012 03:00 PM
evade_07
Dec 13, 2008 10:15 PM
hatchsi0485
Nov 21, 2005 06:13 AM
amerikinjesus
Apr 9, 2004 11:52 PM
