eg with gsr radiator
I am goign to install the gsr radiator into my eg coupe and was wondering what others did to accomplish this. i found this http://www.hybridautomotive.com/tech/teg_rad/ but it seems alittle too much work. just need some ideas. thanks
Guest
Posts: n/a
pm eg_nezay on the board...he did some custom fab on his radiator...its a pretty simple task it just takes some time...a lot of people like to have the bigger radiator for autox and roadracing.if you dont want to do that kind of fab then get a del sol dual core radiator
I used an air hammer to knock my OEM mounts off, then I held the radiator where I wanted it and welded the mounts back on (for the bottom). The top mounts are different too. so I took the stock mount, bent it into shape and used a self-tapping screw to secure it to the car. worked good
navin
32
Aug 21, 2010 07:09 PM
crzymine03
Aug 29, 2004 11:19 AM
Hard2Find
Oct 18, 2002 05:13 AM
