MSD cap conversion and external coil wiring, what to use and what to bypass
Old May 24, 2003 | 06:35 PM
insane900rr's Avatar
Default MSD cap conversion and external coil wiring, what to use and what to bypass
ok, i got the MSD cap conversion and Blaster 2 coil and i was wondering what wires that were used on the distributor for the coil and did you by-pass the ICM (ignition control module). The directions from MSD are very incomplete. Let me know, thanks I'm buying
Old May 24, 2003 | 07:28 PM
pornstarSR's Avatar
Default Re: MSD cap conversion and external coil wiring, what to use and what to bypass (insane900rr)
when i did the conversion on my civic it was pretty straight forward....yeah i know the msd instructions are kind of vague...
one thing that i noticed is on the internal coil it has a + and - sign on the terminals which are the ones you have to connect to for the external coil
if you have any other connections let me know ill try to help
Old May 24, 2003 | 08:06 PM
TREVER's Avatar
remove stock coil
run the two coil wires to the new coil
there marked + and - on both coils
Old May 25, 2003 | 04:44 AM
Xsi's Avatar
Xsi
http://www.integraxsi.orcon.net.nz/msd
honda_SiRII94
Apr 9, 2007 08:14 AM
dc4teg95
Nov 21, 2006 02:08 PM
iiilgsrlll
Oct 3, 2004 07:57 PM
boostin b16
Mar 18, 2003 12:32 PM
