Puttin on new distributor, how can i get timing exactly back to where it was before?
Old May 24, 2003 | 04:57 PM
IloveNewt's Avatar
Default Puttin on new distributor, how can i get timing exactly back to where it was before?
Im gonna put a new dizzy on, and i was wondering is a timing light precise enough?
I have a hondata and im afraid that if i put the dizzy back a hair off the original setting, the timing that the hondata adds/removes is gonan be off because of the new dizzy and then kabooom.
Any ideas? Is a timing light precise enough to handle this, cause even with i have a ligth on the flywheel, its fluxuates slightly.
Old May 24, 2003 | 05:07 PM
turbod16y8's Avatar
Default Re: Puttin on new distributor, how can i get timing exactly back to where it was before? (MordecaiPS
get a timimng gun and time it.
Old May 24, 2003 | 05:08 PM
EVOLMTR's Avatar
Shoot timing on your car to see how many degrees advance or retard it's set at. After you install your new distributor shoot timing agian and make sure it's at the same setting. That's what timing lights are designed for; precise timing.
It's best to use a digital timing light ( i.e. snap on, mac) So, you can know exactly what timing is set at.
Make sure you jump your service connector.
Old May 24, 2003 | 08:30 PM
IloveNewt's Avatar
I know, i have a timing gun. The question is, is the timing gun precise enough.
Old May 24, 2003 | 08:32 PM
tony1's Avatar
It doesn't get anymore precise than that...
tctruong94
Apr 27, 2017 11:10 AM
sikek1
Apr 28, 2008 05:49 AM
miksew
Jun 7, 2006 08:03 AM
johnbrooke86
Aug 23, 2004 04:49 PM
Tx92AccordExD
Jul 22, 2002 11:13 PM
