Master cylinder swap?
Old May 24, 2003 | 04:52 PM
96Prelord's Avatar
Default Master cylinder swap?
Well my master cylinder on my 96accord has pooed out on me. I've read of people upgrading to other MC, but i was wondering if one out of a 95 lude vtec would work fine. Its a great price and its at the closest junkyard to my house. I have F&R disc brakes so thats no worry. The lude one had only 28K miles on it so i know its still in good condition. So will it bolt right up or no?
Old May 25, 2003 | 04:02 PM
96Prelord's Avatar
Come on you guys, i g/g my car back on the road SOON. Im sure somebody has some info on this!!!
Old May 29, 2003 | 03:12 PM
WhitEdRift's Avatar
Default Re: (96Prelord)
Wish I knew. I have to replace mine also. I hear that when it craps out that the seal in it is broken causes pressure loss. I am just going to try and fix mine instead of paying a mechanic $400 to replace it. If the part is the same size and has the same bolt holes as the Prelude then it should fit.
Old May 29, 2003 | 03:15 PM
b18bEG's Avatar
it should work, im thinking. most lude accord things are interchange-able. about to do mine, i would sure like to know
Old May 29, 2003 | 03:24 PM
RotaryBzzzz's Avatar
Default Re: Master cylinder swap? (96Prelord)
check part numbers to be 100%. Is your life worth saving a couple bucks?
Old May 29, 2003 | 03:42 PM
One2chi's Avatar
Default Re: Master cylinder swap? (RotaryBzzzz)
when you replace make sure to replace the slave at the same time.
supposed to do that....or so i hear, maybe someone else knows why.
Old May 29, 2003 | 06:57 PM
WhitEdRift's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RotaryBzzzz &raquo;</TD></TR><TR><TD CLASS="quote">check part numbers to be 100%. Is your life worth saving a couple bucks? </TD></TR></TABLE>
When it's my money, yes! rofl
I'm not going to even think twice about having a shop do my replacement.
Old May 29, 2003 | 09:34 PM
smokin rubber's Avatar
Default Re: Master cylinder swap? (One2chi)
I think it will fit, but it will only change pedal feel, not stopping power.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by One2chi &raquo;</TD></TR><TR><TD CLASS="quote">when you replace make sure to replace the slave at the same time.
supposed to do that....or so i hear, maybe someone else knows why.</TD></TR></TABLE>
There is only a slave cylinder for the clutch, no brake slave cylinder.
Old May 30, 2003 | 01:48 AM
TypeSH's Avatar
Default Re: Master cylinder swap? (smokin rubber)
if you do try it and find it works, can you measure and document the swap? I'd be interested if this is a larger MC upgrade.
btw, do you have ABS or not? i believe all 5th gen accords w/ ABS used one MC while non-ABS accords used a diff MC.
j3wman
Jun 27, 2012 03:16 PM
5.0 Killa
Suspension & Brakes
Oct 29, 2009 10:40 AM
CuttingEdge SI
Jul 30, 2005 11:48 AM
JobberRadio
15
Nov 30, 2004 07:13 AM
sleepyhamsterlx
Mar 29, 2004 02:33 PM
