B16 bottom with GSR head?
Old Jul 13, 2001 | 04:16 AM
integ94's Avatar
New User
Default B16 bottom with GSR head?
Just curious to know if anyone has this setup and what are the advantages or disadvantages?
Old Jul 13, 2001 | 05:29 AM
92Si's Avatar
New User
Default Re: B16 bottom with GSR head? (integ94)
I am not a big fan of the GSR intake manifold. I guess if you purchase a Skunk2 manifold or modify an R/b16 manifold, you will be stuck with it. A friend of mine here in Florida used to run a B16 block with GSR head and it was strong, although the head was a bit warped and he ended up junking it for a B18c5/gsr combo. If you are in the process of building a GSR block or LS/CRV, it should keep you happy until the project is done.
Old Jul 13, 2001 | 06:07 AM
LRAO's Avatar
The GS-R head has a smaller combustion chamber, which will increase compression by a tad.
If you're going to do that, then you should do the following:
Spoon 1-piece headgasket (also increases compression)
Skunk2 or modified ITR intake manifold
Loc
slowB20ej8
May 19, 2008 12:19 PM
racingfan
13
Sep 6, 2005 02:09 AM
1991hondahead
Sep 7, 2004 02:52 PM
OreoEF8
27
Aug 20, 2004 10:16 PM
BoOsTeD_eK
Jun 14, 2002 06:56 PM
