Ingalls front camber kit install.....
Old May 24, 2003 | 01:46 PM
toooslow's Avatar
Default Ingalls front camber kit install.....
Do you have to remove the whole strut to install the kit? If you could give me directions that would be great.
Old May 24, 2003 | 01:55 PM
hollaback6's Avatar
Default Re: Ingalls front camber kit install..... (whiteinteg95)
didn't you get directions with the kit? That is what i used.
Old May 24, 2003 | 01:56 PM
hollaback6's Avatar
oh and you don't have to remove the strut to install the kit.
Old May 24, 2003 | 03:12 PM
Lei Siew Long's Avatar
there's a brace on two of the factory anchor bolts for each side that is located BEHIND the strut. so, if you have access to a dremel, you can cut the brace so you would be able to swing the upper control arm around so the upper control arm would be able to rest on top of your tire. if you don't have access to some sort of cutting tool, just remove the strut assembly so you would be able to swing the upper control arm around.
for my install, i tried to take that brace off the stock anchor bolts to mount it on the ingalls camber kit but, i had no luck on trying to make that thing budge.
Old May 24, 2003 | 06:48 PM
toooslow's Avatar
Default Re: Ingalls front camber kit install..... (Hatch4urSnatch)
Thats the problem im having, its with the brace. Is the brace suppose to just pop off normaly or what, it wont budge. Would it affect anything to cut it?
Are there anyother bolts that i have to take off besides the two 14mm ones at top of tower?
Old May 24, 2003 | 07:07 PM
xteg95's Avatar
http://student.ucr.edu/~ohe02/ hes got a good write up on the camber install.
Old May 24, 2003 | 08:41 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by whiteinteg95 &raquo;</TD></TR><TR><TD CLASS="quote">Thats the problem im having, its with the brace. Is the brace suppose to just pop off normaly or what, it wont budge. Would it affect anything to cut it?
Are there anyother bolts that i have to take off besides the two 14mm ones at top of tower?</TD></TR></TABLE>
to my knowledge it won't effect anything. just cut it off. if not, take off the strut and spring assembly. besides the nuts on top of the shock tower, there are the nuts and bolts that bolts the factory anchor bolts to the upper control arm.
and for the link above, the skunk 2 camber kit and ingalls are two different types of camber kits. the skunk 2 is the entire upper control arm while the ingalls just replaces the anchor bolts to swing the factory upper control arm in and out.
Old May 25, 2003 | 03:02 PM
toooslow's Avatar
I just installed passenger side today. Decided to take off whole strut assembley, didnt take too long. Seems to have came out good.
Old May 25, 2003 | 04:17 PM
Default Re: (whiteinteg95)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by whiteinteg95 &raquo;</TD></TR><TR><TD CLASS="quote">I just installed passenger side today. Decided to take off whole strut assembley, didnt take too long. Seems to have came out good.</TD></TR></TABLE>
Old May 27, 2003 | 08:24 AM
toooslow's Avatar
I installed both sides of the camber kit today. Car feels too damn weird. It feels like there is no weight in the front of the car and steering is unbelievebly loose. The front tires get no traction at all. Tires look perpendicular to the ground. The only thing is that when i have one tire straight, the other is turned out just a little. Can someone tell me how to adjust this. Could this be the cause of the loose steering.
Old May 27, 2003 | 10:56 AM
jeebusm3's Avatar
I'm gonna have to guess that your toe is way out of spec? Don't you need an alignment after a camber kit install?
Old May 27, 2003 | 11:09 AM
PupaScoopa's Avatar
Yes the alignment changes as you adjust the camber:
You get toe out when you increase camber, toe in when you reduce it.
Old May 27, 2003 | 03:16 PM
toooslow's Avatar
Could you give me directions on how to adjust toe in or to out, i want to somewhat try to adjust it because I cant take it to a pro alignment shop for another week until i get some $$$$
And should i expect a typical alignment shop to adjust camber and toe or do I have to do all the adjusting, Whats an estimate of how much $ it will cost?
Old May 27, 2003 | 04:52 PM
ebelp's Avatar
Default Re: Ingalls front camber kit install..... (xintegra01)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xintegra01 &raquo;</TD></TR><TR><TD CLASS="quote">http://student.ucr.edu/~ohe02/ hes got a good write up on the camber install. </TD></TR></TABLE>
That's for the Skunk2, not the Ingalls. Still a good writeup though.
Old May 27, 2003 | 04:57 PM
NeoGSR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by whiteinteg95 &raquo;</TD></TR><TR><TD CLASS="quote">Could you give me directions on how to adjust toe in or to out, i want to somewhat try to adjust it because I cant take it to a pro alignment shop for another week until i get some $$$$
And should i expect a typical alignment shop to adjust camber and toe or do I have to do all the adjusting, Whats an estimate of how much $ it will cost?</TD></TR></TABLE>
take it to a tire shop and they will do all the adjustments for you....alignment usually is around $45-50 bucks.....
i wouldn't drive it too much with it out of line
Old May 28, 2003 | 02:50 PM
toooslow's Avatar
How can i adjust the toe on my integ for now, cant get to alignment shop for a week, and want to somewhat try to fix it
chestnut_55
Oct 23, 2005 03:24 PM
Prelude94
Mar 25, 2004 03:56 AM
Steve90HB
Sep 4, 2003 12:47 PM
Fooser
Mar 28, 2002 07:59 AM
96whitels
Feb 1, 2002 07:12 PM
