Help with KYb's! :(
Old May 24, 2003 | 11:24 AM
Mark's Avatar
*Bounty Hunter*
Default Help with KYb's! :(
Ok so I got to put on my Skunk2's/AGX's today...After 5 hours of rusted bolt madness we got to put everythin in.
When adjusting the height, the rear shocks/coils dropped just right...but the front shocks wouldnt budge. They stood at a high setting and wouldnt compress under the car's weight. We assembled the shocks the way theyre supposed to be according to the diagrams...But it wouldnt budge for some reason. Any clue as to what is preventing the shock from compressing?
Old May 24, 2003 | 11:38 AM
P1mpSlap's Avatar
Did you put that metal sleeve back on the front?
If so. remove it. So you dont have to cut the bumpstops.
Old May 24, 2003 | 01:23 PM
SHystrdyGSRtdy's Avatar
Default Re: (P1mpSlap)
metal sleeve? so if you don't use the "metal sleeve" you don't have to cut the bump stops?
Old May 24, 2003 | 04:32 PM
P1mpSlap's Avatar
Default Re: (iLUVmySH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iLUVmySH &raquo;</TD></TR><TR><TD CLASS="quote">metal sleeve? so if you don't use the "metal sleeve" you don't have to cut the bump stops?</TD></TR></TABLE>
It really depends on how low your car is lowered.
The metal or plastic sleeve is really jsut a dust cover for the shock. If you have your car SLAMMED and pancaked on some coilovers. You could cut the front bumpstops just a little bit so it doesn't bottom out.
I had skunk2 coils on my 97 Civic, my car was lowered all the way it could go, and then some with the help of a camber kit (yeah, I was a stunna). No problems at all with bottoming out.
But removing the metal sleeve will definatly help. If it still bottoms out. Cut the bump stop. Worse thing is you'll have to remove the shock 1 more time.
ecksman
Jan 4, 2007 05:35 PM
DaveSi677
Oct 12, 2006 11:24 AM
Flava
Suspension & Brakes
May 29, 2006 11:25 AM
tony
Jul 22, 2003 06:14 PM
4potnick
Jun 5, 2003 05:44 PM
