what do i need to run 10psi????
Old May 24, 2003 | 11:09 AM
single cam vtecn's Avatar
Default what do i need to run 10psi????
i was wondering if a apexi v-afc or a votrech fmu?? i will spend extra money on managment parts so my motor wont blow up. i have dsm 360cc injectors and a dsm fuel pump. so far thats it. i wanted to get more research before i go and waste money. thanx
Old May 24, 2003 | 11:20 AM
boostincoupe's Avatar
From: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
Default Re: what do i need to run 10psi???? (single cam vtecn)
My planned setup for 5.5-7psi:
Greddy SOHC kit
1G DSM BOV
1G DSM SMIC
Walbro 255lph HP pump
greddy blue box
stock injectors under 7 psi, RC 310cc or DSM 450cc for 10 psi
Old May 24, 2003 | 11:29 AM
Broken Gearbox's Avatar
Default Re: what do i need to run 10psi???? (fnananon)
shoulda got DSM 450cc inj. and a AFC controller with a Walbro fuel pump
Old May 24, 2003 | 01:26 PM
CivicSoul's Avatar
Default Re: what do i need to run 10psi???? (Powered By D15)
Contact Zip! He is the creator of the SMC, and the smc 500 or smc dual would be all you need. For the price you cant go wrong! I just upgraded to the dual and in the process of tuning it. The SMC plus worked like a champ!
Old May 24, 2003 | 01:28 PM
CivicSoul's Avatar
Default Re: what do i need to run 10psi???? (CivicSoul)
you would need 450's but then you don't have to run higher fuel pressure! For $150ish it is a great deal!
Old May 24, 2003 | 01:42 PM
@irborne's Avatar
i have the DSM 450cc injectos and the wire clip that goes to it. PM me if you wait them.
Old May 24, 2003 | 01:51 PM
Tomek's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by single cam vtecn &raquo;</TD></TR><TR><TD CLASS="quote">i was wondering if a apexi v-afc or a votrech fmu?? i will spend extra money on managment parts so my motor wont blow up. i have dsm 360cc injectors and a dsm fuel pump. so far thats it. i wanted to get more research before i go and waste money. thanx</TD></TR></TABLE>
What dsm has 360cc injectors? The automatic talon/eclipse/laser turbos have 390's and the 5spd's have 450's.
fmu If you dont go standalone then go with the afc/smc hack. For the hack you'll need larger injectors such as the 450s.
Ive had my car running for almost a week with the hack(tuned on a wideband) and it runs very strong at 6-7psi. Only problem is I may have already blown the headgasket Make sure your motor is up to date with maintenance before you crank it up to 10psi.
Old May 24, 2003 | 05:59 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Powered By D15 &raquo;</TD></TR><TR><TD CLASS="quote">shoulda got DSM 450cc inj. and a AFC controller with a Walbro fuel pump </TD></TR></TABLE>
I'm going to run the blue box for lower boost because I don't want to deal with timing issues and drivability issues also. When I want to run 10 lbs. though (not now), I'll probably run the hack, but my car won't be a daily driver anymore by that time (hopefully).
Old May 24, 2003 | 07:30 PM
so if i get a v-afc and some 450's + tuning i could run 10psi? i have another motor waiting for building and some ls rods and pistons. would they work and are they good for higher psi? what size piping too? i have alot of 2.5" oh yeah and one more ? what kind of times would i be looking at with this turbo set up? i have a 92 civic vx with a 95 d16z6, test pipe, and 2.5" exhaust? i wanna run 6 psi daily and 8-10 at the track. thanx for any input.
Old May 24, 2003 | 07:37 PM
Quad-Damag's Avatar
Stock Greddy Kit with Intercooler and BOV
10 PSI
RC 440CC with a OBD 1 Clip or OBD 2 Clip
Missing Link
V FAC
High Flow Fuel Pump Anything 255 or more, is all u need
It's a bit Pricy to do, but this will run 10 PSI like nothing
I would also upgrade your clutch if you plan to do this
Old May 24, 2003 | 07:39 PM
Quad-Damag's Avatar
Default Re: what do i need to run 10psi???? (Quad-Damge)
LVt
1k - -42
2k - -41
3k - -41
4k - -41
5k - -39
5500 - -38
6k - -38
6500 - -37
HVt
4k - -40
4500 - -39
5000 - -38
5500 - -37
6k - -37
7k - -36
8k - -36
9k - +/-0 (My car doesn't rev that high)
Thanks To SleeperCivicEX99 who runs 10 psi daily on his kit with these setting
Old May 24, 2003 | 09:57 PM
what lph is a dsm fuel pump?
Old May 25, 2003 | 07:28 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Quad-Damge &raquo;</TD></TR><TR><TD CLASS="quote">LVt
1k - -42
2k - -41
3k - -41
4k - -41
5k - -39
5500 - -38
6k - -38
6500 - -37
HVt
4k - -40
4500 - -39
5000 - -38
5500 - -37
6k - -37
7k - -36
8k - -36
is this the settings to the v-afc?
Old May 25, 2003 | 07:34 PM
Daniel's Avatar
I had my car dyno tuned on the AFC hack with RC 440s and a Walbro 255. the settings the tuner used were:
1K: -45%
2K-7K: -40%
All the way through for both high and low throttle settings with the throttle points at 98/99%. Worked well but my fuel pump made it run a little too rich. i probably could've gotten away with the stock pump.
Old May 25, 2003 | 07:37 PM
Default Re: what do i need to run 10psi???? (Daniel)
u think a dsm pump will be ok?
Old May 25, 2003 | 09:24 PM
Quad-Damag's Avatar
yes<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by single cam vtecn &raquo;</TD></TR><TR><TD CLASS="quote">
is this the settings to the v-afc?</TD></TR></TABLE>
Old May 25, 2003 | 09:41 PM
BlackDeuceCoupe's Avatar
HT White Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by single cam vtecn &raquo;</TD></TR><TR><TD CLASS="quote">...i wanted to get more research before i go and waste money. thanx</TD></TR></TABLE>
Better play it safe...
<u>BLOW OFF VALVE SOUND FOR ANY NON-TURBO CAR! </u>
After setting a trigger RPM level through an adjustable RPM ****, every time you reach the set RPM, the SUNAMI will simulate the"psssssst" noise generated from the blow off valve of a turbo. An additional override button also allows you to trigger the SUNAMI at any RPM. Equipped with a 4 wire EZ INSTALLATION guide.
http://www.sunamiturbo.com/
-slow ej-
Mar 28, 2005 09:40 AM
boostincoupe
Sep 30, 2004 03:07 PM
turboant
Nov 22, 2003 03:15 AM
boostincoupe
Oct 6, 2003 06:53 AM
B20-T
Feb 20, 2003 02:16 PM
