Valvespring and retainer choice
Old Jul 12, 2001 | 11:28 PM
ninjaman's Avatar
New User
Default Valvespring and retainer choice
It looks like I'm going to put in the Skunk2 cams instead of the Spoon due to the fact I can get them $300 cheaper. I'm trying to decide on valve springs and retainers that will let me safely rev to 9000. I want to be very safe, but not overly stiff if I can avoid it.
Can anyone offer me some advice on which valvespring/retainer combo would work best for me? Thanks in advance. (Please direct any suggestions to get Toda cams to /dev/null)
Old Jul 13, 2001 | 11:21 AM
ninjaman's Avatar
New User
Default Re: Valvespring and retainer choice (ninjaman)
ttt
Old Jul 13, 2001 | 11:35 AM
Mike K's Avatar
You won't need to rev to 9000, because the Skunk cams make peak power way before then. I would suggest some stock ITR springs and Portflow Titanium retainers. You will be perfectly fine with that combo.
Old Jul 13, 2001 | 11:49 AM
ninjaman's Avatar
New User
Default Re: Valvespring and retainer choice (Mike K)
The Skunk2's peak at ~8600, you think ITR outers w/ Portflow inners and retainers and GSR valves will be ok as a daily driver?
Old Jul 13, 2001 | 01:14 PM
Blade's Avatar
New User
Spend the extra cash and get the Spoon's or A's. The valve train isn't a system of the vehicle you want to go cheap with.
Old Jul 13, 2001 | 03:42 PM
FAST94GSR's Avatar
New User
Default Re: Valvespring and retainer choice (Blade)
I shift with my skunks at 9 even though peak power is around 8.6k. Go with web cam or jun or whoever is reputable, they make good springs and retainers. Don't mess around with valvesprings get the best. When you're at high rpms your engine will thank you.
You'll like those cams trust me.
Old Jul 13, 2001 | 11:21 PM
t's Avatar
t
portflows inner would be a little stiff for those cams. I believe type r springs all around work well.
The JUN or Toda springs would be overkill for those cams, causing valvetrain power loss.
Titanium retainers are good, but not necessary unless you plan to be in the 8500-9000 range for minutes at a time.
Old Jul 14, 2001 | 12:04 AM
ninjaman's Avatar
New User
Default Re: Valvespring and retainer choice (t)
What about Skunk2 or Web Cam springs? How do they compare in stiffness to the Portflows or Crowers?
Old Jul 14, 2001 | 12:07 AM
t's Avatar
t
I have no experience with either.
But you cant go wrong with ITR springs.
xfrankx
Apr 25, 2005 06:07 PM
10K2HVN
Jan 16, 2003 02:34 PM
CRXSleeper
Sep 9, 2002 10:47 PM
sa21199
Feb 25, 2002 05:46 AM
Black R
Jun 15, 2001 06:58 AM
