putting car into gear
i'm having a real big problem putting the car into gear, not quite sure whats wrong but i do have a short shift kit installed
its been in there awhile, about a year
just started happening a couple days ago and its really bad right now
can't even put it into first
car is a 1991 integra
anybody have any ideas?
doug
doug
If it goes into gear easily when the engine is not running, and hard when it is, then the clutch is not releasing properly. If running or not does not make a difference, then it is probably the shifter. Synchros are to match gear speeds when moving and will not make it hard to shift into gear when stationary. Is it only first gear, what about reverse? What about trying to put it into 2-5?
If I remember right, most short shifters extend the shifter lower past the pivot point than the stock shifter. Could it be hitting or binding on the heat shield above the exhaust? I would definately check all the links and pivot points to make sure something is not falling apart. A pin or link may be coming out and making it bind. Find out before it falls all the way out and you are stuck in whatever gear your are in then.
i am going to get it checked out either tommorow or sunday
clutch goes in fine
have problems getting it into gear when engine is on and off
yes it is also every gear
i have a feeling its the slave cylinder
thank you all who replied, i appreciate it
clutch goes in fine
well, finally got to take a look and it seems my clutch is on its last life
damn cable tranny!
it's just my luck that i was going to replace my clutch next week, and it dies this week (when i have finals)
damn cable tranny!
onyx00
Jul 26, 2002 06:57 PM
