How To: A/C Kill Switch with pictures
Old May 23, 2003 | 03:39 PM
crxforum's Avatar
Default How To: A/C Kill Switch with pictures
I uploaded it to my server so you can click this link.
http://crxforum.productionz.ne...r.htm
CRX Forum
Old May 23, 2003 | 03:46 PM
rjardy's Avatar
Default Re: How To: A/C Kill Switch with pictures (crxforum)
FLIPPEN FIREWALL, i cant look
Rob
Old May 23, 2003 | 04:00 PM
USDM 4G VTEC's Avatar
pretty ingenius...
and thanxs for the tips!
Old May 23, 2003 | 04:30 PM
audioroach's Avatar
Default Re: How To: A/C Kill Switch with pictures (USDM 4G VTEC)
Okay A for effort,but you have got to learn how to use SPDT
(single pole double throw) relays.....once you understand how
they operate the world is your oyster....The olny problem i see
in the design is that you are throwing a large amount of current
which can/may overload the switch...just a thought
Old May 23, 2003 | 04:35 PM
crxforum's Avatar
Default Re: How To: A/C Kill Switch with pictures (audioroach)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by audioroach &raquo;</TD></TR><TR><TD CLASS="quote">The olny problem i see
which can/may overload the switch...just a thought</TD></TR></TABLE>
How do you see that? The speakers are attached to the car battery. Now is that not the same current that is running to the ignition? The switch is just speaker male and female ends. The wire is 14 gauge so it is more than enough. I took the wire from a trailer real light harness. It will be fine.
CRX Forum
Old May 23, 2003 | 04:43 PM
Neukin's Avatar
to bad my car didnt come with A/C... o well i know how to start yours ill just steal it! just messin, good job, that's pretty cool.
Old May 23, 2003 | 05:01 PM
4drEF's Avatar
Keyboard Humorist
That's cool and all, but why didn't you just use the prongs on the back along with a relay??? Was there a possible problem with going that route?
Old May 23, 2003 | 05:05 PM
audioroach's Avatar
Lets see...you are using a switch to re-connect a high current
circuit system which may not be duty rated to handle that load.
....but then with well over 10 years of installing what do I know?
Here is a link that may help you out:
If the switch is non working....you could connect one side to ground
and use the other side to connect to that would be an alarm interupt
output. This would provide a much better way to do you circuit.
Good luck
Modified by audioroach at 8:37 PM 5/23/2003
Old May 23, 2003 | 05:40 PM
sparkz's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxforum &raquo;</TD></TR><TR><TD CLASS="quote">I uploaded it to my server so you can click this link.
CRX Forum</TD></TR></TABLE>
this is a good idea, but poor execution. your method does work, but its not a great way to do it.
what i wouldve done is use a relay in NO (normally open) config and use the a/c wire coming from the ecu as a trigger.
Old May 23, 2003 | 10:45 PM
EvlErn69's Avatar
New User
Default Re: How To: A/C Kill Switch with pictures (sparkz)
i had the same i idea damn i wouldnt think anyone else would do the same thing... now i gots to change it.. i have some AC buttons for sale... just pm..
Old May 23, 2003 | 11:04 PM
MADEINIRAQ's Avatar
Default Re: How To: A/C Kill Switch with pictures (EvlErn69)
why didn't you just use the switch wiring its self ... you made a switch into a 3rd world country type of switch..
still works..
Old May 24, 2003 | 12:03 AM
crxforum's Avatar
Default Re: How To: A/C Kill Switch with pictures (madeiniraq)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by madeiniraq &raquo;</TD></TR><TR><TD CLASS="quote">why didn't you just use the switch wiring its self ... you made a switch into a 3rd world country type of switch..
still works.. </TD></TR></TABLE>
Because I dont have sergical plyers to get into all the small little cracks. This saved hours of time. I tested it out and it works perfectly. There are no problems. I have a bunch more switches (4 in total) that will cover me if anyone who steals my car reads this thread.
CRX Forum
Old May 24, 2003 | 03:10 AM
audioroach's Avatar
I admit its a great idea...I do "ghost switches" all the time.
I was just trying to pass on a little knowledge to help you
grow....just trying to keep you from being stranded by a
circuit that works great now.
Ps This is also a part of your pager circuit you want to create....
I could give you the design step by step,but what fun would that
be...plus its a great way to learn...
Old May 24, 2003 | 04:53 AM
d357r0y's Avatar
I like the P.S. the most.
You are Gay. that made me laugh.
Old May 24, 2003 | 05:46 AM
FourthGenHatch's Avatar
Default Re: How To: A/C Kill Switch with pictures (d357r0y)
That is sort of a ghetto way of doing it if you ask me, unless you have a relay or something than eventually the prongs will bend or something. Seems to me it would be better to utilize the original wires hooked to a relay or some sort.
Old May 24, 2003 | 08:51 AM
keebler65's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by madeiniraq &raquo;</TD></TR><TR><TD CLASS="quote">you made a switch into a 3rd world country type of switch..
lol nice description. yeah personally i would have used the existing switch and just triggered a relay. i'm sure that over time that spade connector will get loose and not make reliable contact. nice idea though.
Old May 24, 2003 | 02:24 PM
escocrx's Avatar
always good to tell the world about things like this. just more tips on how your system works for an easy getaway
Old May 24, 2003 | 04:23 PM
RCautoworks's Avatar
Make sure when you put the switch back in it don't look like you've been messing with it, cause then someone trying to steal you car might see its been messed with an catch on.
Modified by 90blackcrx at 8:28 PM 5/24/2003
Old May 24, 2003 | 05:55 PM
crxforum's Avatar
Default Re: How To: A/C Kill Switch with pictures (90blackcrx)
When you put the switch back in you cant tell a thing. It is flush and there are no exposed wires or anything.
CRX Forum
Old May 24, 2003 | 08:50 PM
G2turbo_terror's Avatar
like mentioned above, make sure the switch is properly rated, don't ask how I know...
Old May 27, 2003 | 10:52 AM
EvlErn69's Avatar
New User
Default Re: How To: A/C Kill Switch with pictures (G2turbo_terror)
you coudl use the switch but when you use the og switch it will burn out...
Old May 27, 2003 | 10:58 AM
slowpokesi's Avatar
so, what happens at nigh when the the theif turns on your lights before he steals the car and notices that all your dash lights work except for your ac light?
Old May 27, 2003 | 11:23 AM
wickedEFguy's Avatar
I like the idea and it's cheap and effective but like some of the others were saying I would as well use the A/C switch to activate a relay that connects the ignition together so when the A/C switch is off you can't start your car but when it's on you can, But still that gave me some good idea and thanx for the new info
mrdeadman
Audio / Security / Video
Sep 23, 2006 08:52 AM
Supremacy
Mar 19, 2005 04:11 PM
Mini-mEK4
Oct 19, 2004 01:25 PM
elwood
Sep 18, 2004 11:37 PM
crewjones
Oct 27, 2003 06:51 AM
