my bypass valve broke for my AEM CAI!!
Old May 23, 2003 | 08:48 AM
hYpE-R-29's Avatar
Default my bypass valve broke for my AEM CAI!!
My bypass valve broke, so I put a 3 inch PVC pipe with clamps between the gap where the bypass valve used to be. My question is will I lose power or gain with the PVC pipe?
Old May 23, 2003 | 08:51 AM
B2FiNiTY's Avatar
Default Re: my bypass valve broke for my AEM CAI!! (hYpE-R-29)
Not suprised...
You won't be loosing power with the pvc pipe as long as it is smooth and does not add turbulence.
Old May 23, 2003 | 08:57 AM
hYpE-R-29's Avatar
Default Re: my bypass valve broke for my AEM CAI!! (B2FiNiTY)
its louder for sure, the smooth part I dont understand because when I installed the pipe it was like a bubble in the middle of the pipe...should I smooth that part out
Old May 23, 2003 | 08:59 AM
B2FiNiTY's Avatar
When I say smooth I mean smooth like the rest of the intake. You don't any bumps that will block air flow.
Old May 23, 2003 | 09:02 AM
hYpE-R-29's Avatar
ok thanx...
Old May 23, 2003 | 10:18 AM
JumbosGS-R's Avatar
New User
AEM backs up all their products. Call them and I'm sure they will send a replacement.
Old May 23, 2003 | 10:39 AM
PM-Performance's Avatar
Default Re: my bypass valve broke for my AEM CAI!! (JumbosGS-R)
They will replace it , they replaced 4 for me until i got pissed and got my money back
Old May 23, 2003 | 12:09 PM
s2k420's Avatar
Default Re: my bypass valve broke for my AEM CAI!! (itr206)
Hahahah your by pass valve broke too huh? Welcome to the club Mine broke about 3 weeks ago.
Old May 23, 2003 | 01:01 PM
00MRSi's Avatar
Default Re: my bypass valve broke for my AEM CAI!! (JDmMugeNItR)
A few years back they had sent out a memo regarding defective bypass valves. I called them up (almost 2 years ago) and they sent me a clip to install so that in case the bypass valve brakes it won't get sucked into the TB. Mine seems to be fine.
I'd just call up AEM and tell them. They should send you a replacement..
Rainmaker
May 30, 2007 06:45 PM
PearlBlueType-S
10
Dec 25, 2005 01:34 AM
Beezle
Dec 3, 2004 01:09 PM
Fidelio25
Jul 4, 2004 05:41 PM
90TegRex
Nov 17, 2002 08:06 PM
