b18c pistons and rods into b18b engine
Old May 23, 2003 | 08:26 AM
itrlu77's Avatar
Default b18c pistons and rods into b18b engine
would this work: b18c pistons and rods into b18b engine and crank with a b18b head. thanks you.
Old May 23, 2003 | 09:00 AM
Newman's Avatar
New User
Default Re: b18c pistons and rods into b18b engine (itrlu77)
Nope. GSR stroke is shorter than the LS stroke, so if you use GSR rods, you need to use the GSR crank. If you use the LS rods, then you need to use the LS crank.
Old May 23, 2003 | 09:02 AM
b19coupe's Avatar
Use B18C pistons and modified LS rods (small end machined narrower). ARP rod bolts are your friend, too.
speedciv
Jun 22, 2013 11:15 AM
liquidrider
Dec 7, 2009 04:07 AM
beyondstock
Mar 8, 2009 12:41 AM
RACING INTEGRATION
Oct 27, 2004 02:16 PM
TspEk9
May 14, 2004 02:39 AM
