JDM front sway bar for ITR??? how big
98 spec is 25mm. Unfortunately, it won't fit an ek.
You need to buy a CTR or Civic Si (same thing, 26mm) front sway, along with the lcas and shock forks.
this is the thing i have a 99 acura 1.6EL which has ITR lower control arms the tie rod style end links. so if the bar fits over the hump and stuff it will work i assume
ok thing is id have to change my control arms i have ITR ones on the front basicaly and SIR use stamp steal ones
royalrebel
Suspension & Brakes
Dec 19, 2008 04:49 PM
