b 16a in 93 coupe not starting
Old May 23, 2003 | 07:17 AM
DOHc SIdE's Avatar
Default b 16a in 93 coupe not starting
it cranks but wont start everything is plugged in except the knock sensor
could that be why its not strarting up, and if it is how do you wire it up to the computer?
Old May 23, 2003 | 07:56 AM
92b16vx's Avatar
Check all your grounds,and make sure it is static timed to factory specs.
Old May 23, 2003 | 08:13 AM
Turbogixxer's Avatar
Default Re: b 16a in 93 coupe not starting (DOHc SIdE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DOHc SIdE &raquo;</TD></TR><TR><TD CLASS="quote">knock sensor could that be why its not strarting up, and if it is how do you wire it up to the computer? </TD></TR></TABLE>
No, it will start but will not have vtec. For OBD I, the pin out for the knock sensor is D3. I would start with all the wiring you did. Then you need four things for the motor to start: Compression, timing, fuel, and spark. I would start with timing and spark cause those are the ones that are usually off.
Old May 23, 2003 | 06:47 PM
Eg6LazyPt's Avatar
Default Re: b 16a in 93 coupe not starting (turbogixxer)
If it cranks and you smell gas, then check your distributor for spark next. Usually you will have a dead ignition coil. Just did my b16a swap and had the same problem. Don't worry about the knock sensor yet, I still haven't wired in my knock sensor yet and it runs skippy.
93Akkord
Jul 20, 2006 09:53 PM
Kangolbrand
Mar 12, 2006 10:43 AM
streetracerof06
Dec 15, 2005 07:06 AM
duggy
10
Aug 27, 2005 07:01 PM
uk99civicvti
Jul 30, 2001 11:32 PM
