H22 guys I have a question for you
i have a 2000 h22 going into a 94 hatch but i have no dist do i buy a obd1?? and if so its external coil right???need help this is the last thing that i cant figure out
Any H22A distributor (OBD-1 or OBD-2, internal coil or external coil.... doesn't matter) will work. The electronics are the same, but since you have a 94 Civic, then it's easier to get a JDM H22A OBD-1 distributor as it already has an internal coil, so less wiring. If you find a H22 distributor w/external coil, or an OBD-2 distributor, then just rewire it up to work with your Civic harness... that's it.
building boost
Northeast (Sales)
Mar 24, 2007 11:35 AM
