If the rear main seal was leaking....
Old May 23, 2003 | 06:09 AM
shingles's Avatar
Default If the rear main seal was leaking....
wouldn't the back of the flywheel have atleast some amount of oil on it?
Thanks,
-S
Old May 23, 2003 | 06:24 AM
Crazydave's Avatar
Default Re: If the rear main seal was leaking.... (shingles)
on the back side of it..maybe..
you will notice oil dripping from the bottom of the tranny and little drain hole.
pull off the tranny and take a look
Old May 23, 2003 | 08:31 AM
shingles's Avatar
Default Re: If the rear main seal was leaking.... (Crazydave)
Well, I didn't pull the entire tranny, I pulled the dust plate and noticed that it was dry on the block side. The flywheel was dry. My thought was that if there was oil coming out of the rear main it might splash onto the flywheel...
I think I know where the leak might be coming from - the shift rod on the tranny side. The dust boot is torn there.....
-S
Old May 23, 2003 | 10:40 AM
mike1114's Avatar
maybe your header is rubbing your oil pan? This would eventually cause a small leak that gets bigger, and bigger, and bigger....don't ask me how I know!!
Old May 23, 2003 | 12:29 PM
johnzm's Avatar
Default Re: If the rear main seal was leaking.... (mike1114)
my rear main was leaking. the flywheel stays dry unless its spewing because that thing is spinnin FAST. i had alot of buildup on the block side where it flung it everywhere
Old May 23, 2003 | 01:08 PM
shingles's Avatar
Well that's the thing, my block side is clean...
There's no rub on the oil pan so that's ok. I am going to try and replace the boot on the shift rod to see what's up.
-S
Old May 23, 2003 | 03:21 PM
civicVX's Avatar
Default Re: (shingles)
could be your oil pan gasket. yes your flywheel would be wet somewhat or the block. where exactly are you seeing the oil on the car?
Old May 23, 2003 | 04:07 PM
shingles's Avatar
Default Re: (civicVX)
Right where the block and tranny meet, but on the back(intake side) and not the front(exhaust side).
-S
Old May 23, 2003 | 05:07 PM
advanracing62's Avatar
I've got this same issue on my motor... I changed the pan gasket and nothing changed.. the pan is good.. I'm thinking it has to be the main, but i've not pulled it yet.. Also just to be safe... check higher up on the block to be sure that there isn't a leak up there that isn't trickeling down and making you chase things that aren't there. I found my oil pressure sending unit was a bit leaky, but that still didn't solve the whole issue.
Old May 23, 2003 | 06:46 PM
Crazydave's Avatar
Default Re: (advanracing62)
when mine was leaking.. it was obvious..
they oil was all inside.. and coming out..
the flywheel WASN"T covered in oil..but the tranny casing was..
take off the cover and look..
you will see the oil coming from the seal..
if you need to change you clutch.. now would be the time to do that too
btw make sure the new oil seal is ALL THE WAY
Old May 25, 2003 | 02:02 AM
3rdGteg's Avatar
Default Re: (Crazydave)
I'd double check to make sure that the leak is not possibly leaking from somewhere uptop.
2x0
Jul 6, 2017 04:15 PM
Bobby_Budds
May 31, 2010 07:10 AM
kenzo42
Dec 21, 2008 12:21 PM
Dat_One_Si
Feb 13, 2006 06:25 PM
TylerC
Aug 8, 2005 08:13 AM
