Turbo Prep
Old May 23, 2003 | 06:05 AM
abeaujuin's Avatar
Default Turbo Prep
What should I prepare my 94 Accord with 165k for a turbo install? Should I replace the Rods, Pistons, rings, etc... I heard that the compression ratio on my accord is like 8:1 which is perfect for a turbo. Help?
Old May 23, 2003 | 06:58 AM
optimis's Avatar
Default Re: Turbo Prep (abeaujuin)
First buy this book "Maximum Boost" by Corky Bell. It explains everything. Then ask yourself if you want to build your own system or buy a kit.
Old May 23, 2003 | 07:05 AM
eL's Avatar
eL
someone named Corky has to know all the answers haha
Old May 23, 2003 | 07:52 AM
Stew Pidasso's Avatar
Default Re: Turbo Prep (optimis)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by optimis &raquo;</TD></TR><TR><TD CLASS="quote">First buy this book "Maximum Boost" by Corky Bell. It explains everything. Then ask yourself if you want to build your own system or buy a kit.</TD></TR></TABLE>
I read it...Great book!!!
Old May 23, 2003 | 09:03 AM
iam7head's Avatar
Default Re: Turbo Prep (Stew Pidasso)
I read it..more then 20 time..
it answer all my questions..lol
prep? work your *** off and save ALOT of money
Old May 23, 2003 | 11:03 AM
KTeller8's Avatar
Default Re: Turbo Prep (iam7head)
save up and get what you want:
you can get a drag kit: simple cheap: and then work on motor:
or work on motor and hope youll be able to save up again and then buy drag kit:
where you want to be? mild boost/ crazy boost?
think of where your going. then find out how to get there
Old May 23, 2003 | 11:27 AM
AccordDriver92's Avatar
I would replace Rods, Pistons, Valve Springs, Injectors, Camshaft, Cam Gears, ... just build up the motor
Old May 23, 2003 | 11:47 AM
abeaujuin's Avatar
Default Re: Turbo Prep (KTeller8)
I am going for simple boost 5-8 somewhere along those numbers. Where do I get this Drag Kit everyone is talking about?
Old May 23, 2003 | 03:36 PM
KTeller8's Avatar
you can order them with most dealers
we sell drag kits for 2750
accordinglydone.com/store
check it out
navysealsnypre
May 22, 2007 08:57 AM
ohmthugs
May 3, 2007 09:05 PM
Dj Skidz7
May 18, 2006 02:22 PM
phatridinDus10
Jan 26, 2002 09:58 AM
Razor
Nov 25, 2001 11:31 AM
