Front blinkers on 5th gen?
Old May 23, 2003 | 05:29 AM
TRN's Avatar
TRN
Default Front blinkers on 5th gen?
How are the blinker housings fastened in? Are there screws in the back of them?
Anyone cleared these out before?
Old May 23, 2003 | 06:00 AM
SMOOTH97LUDE's Avatar
on the inside where the open is for air to enter into the radiator. take a long screw driver insert it at an angle. a friend did clear his own but i am not sure how, but they were a little scratched. so i think you should just buy the cleared ones
Old May 23, 2003 | 07:30 AM
RAB's Avatar
RAB
Default Re: (
Clear them..... why?
Old May 23, 2003 | 08:03 AM
TRN's Avatar
TRN
I wasn't sure where they attached....thanks though. I saw what you were talking about.
Old May 23, 2003 | 09:23 AM
UniphyedSH's Avatar
Default Re: Front blinkers on 5th gen? (TRNRacer)
Check your manual. Its got a good diagram on where the screws are.
Old May 23, 2003 | 10:10 AM
743's Avatar
743
Default Re: ( (RAB)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RAB &raquo;</TD></TR><TR><TD CLASS="quote">Clear them..... why?</TD></TR></TABLE>
Exactly.
Old May 23, 2003 | 11:10 AM
ludegirl1004's Avatar
I cleared mine out using a soldering iron. It's relatively easy except it does take some patience.
Old May 23, 2003 | 11:21 AM
silver97prelude's Avatar
just buy the clear ones on ebay for $15
Old May 24, 2003 | 07:52 AM
TRN's Avatar
TRN
It only ended up taking like 25 minutes to do. I had my car on the lift and was looking at them. Decided I would just go ahead and do it. Easy
Old May 24, 2003 | 09:48 AM
bullet9925's Avatar
New User
Default Re: (TRNRacer)
it is super easy. Its better than the stock ones because when you stick an orange bulb in it instead of having a plastic orange reflector piece you can't really see the bulb from the front and they look hot when cleared
Old May 24, 2003 | 03:18 PM
743power's Avatar
Default Re: (bullet9925)
dolph lundgren OwnZ j00
Lude-acris
Apr 8, 2005 11:28 AM
FSTASNTZ
Jan 10, 2005 08:37 PM
boosted lude
Aug 9, 2004 02:47 PM
AWR19
Dec 20, 2003 01:17 AM
redluder
May 16, 2002 02:39 PM
