Another IACV question. Should be easy...
Ok, this is what I got.
96 EK with 97 LS and LS ECU.
I have the A12 wiring to pin2 on the sensor, but where does the Blk/Blu wire go? I was told to any power source on the ECU, but where is that. I was told A11, but it have a wire in it, do I just tap into A11 with it?
Basically
Where do I put the Blk/Blu? Specifically.
Basically
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2trix »</TD></TR><TR><TD CLASS="quote">i thought the bottom wire on the clip was for the power and should be blk/ylw!? and then the top wire would goto a12...hmmm...</TD></TR></TABLE>
but where does thepowrer go??????
wait a minute!? is this obd2 or 1? on obd1 i believe that its a 2 plug with power to the bottom plug and signal is is the top plug. in obd2 blk/bl is a12..o is a13 and then power...
Its ODB2
I got the singal and power wires ready, BUT where specfically does the power go. exactly where do I put it. where is the ECU power?
h22accord101
Mar 3, 2015 12:44 PM
hotimportcrx
Feb 6, 2006 11:45 AM
