help^ my lude is makin a knockin sounds at 3500 rpms
Old May 23, 2003 | 12:13 AM
gulf imports
Guest
Posts: n/a
Default help^ my lude is makin a knockin sounds at 3500 rpms
this is for my 94 si h23a1 lude!
help^ my lude is makin a knockin soungs at 3500 rpms, an when i put in first gear with the clutch all the way end an i rev the car to about 3500 it , the car starts to jump, i put a new cluch in it, an its still maken that sound,i pulled the oil pan there way copper shaveing in ther? looked pulled on stuff nothing is is lose! i changed the rod berings an still knockin someone help me save this LUDE!
Old May 23, 2003 | 05:14 AM
CHK4TIX's Avatar
Default Re: help^ my lude is makin a knockin sounds at 3500 rpms (gulf imports)
how many miles on the car? If its not the piston bearings, it could be a main bearing or it could even be a busted oil pump. I had a freind that had a strange noise and we thought it was the bearings but the stock oil pump had busted.
Old May 23, 2003 | 10:01 AM
gulf imports
Guest
Posts: n/a
188 thow miles on the lude we pulled it all oil pan down put all new rod berings in prelude i did not see any thing lose! heLP{
Old May 23, 2003 | 12:06 PM
gulf imports
Guest
Posts: n/a
help me save the lude!
Old May 23, 2003 | 12:24 PM
94PreludeSIH23POS's Avatar
the H23 such you will be beter off with a H22 with a H23 none v-tech head
Old May 23, 2003 | 01:32 PM
silver97prelude's Avatar
good luck, 188g's, wow, honda reliability
H22 swap? Ah yes.
Old May 25, 2003 | 12:14 AM
gulf imports
Guest
Posts: n/a
Default Re: help^ my lude is makin a knockin sounds at 3500 rpms (silver97prelude)
another member is right trust bering!
ESP.net
Aug 19, 2012 05:49 AM
streetracerjoey210
Feb 8, 2009 09:31 AM
Kusai.Nihonjin.Desu
Oct 29, 2004 12:38 PM
damntired42
Jan 13, 2004 02:03 PM
hatchback19
Jul 14, 2003 01:30 PM
