Turbo Fuel management help please.......Thank you first...
HI...Guys/Gals...
I'm about to install drag turbo kit...it somes with Vortech FMU + Airtex high pressure fuel pump..
My question is..i'm planning to run 5-7psi with this FMU+high fuel pump...
Is this a ok setup to run boost?? or any ideas how much boost this is???
Also, if i want a full 7psi boost, what fuel management should I can run?? or even more boost???
Any help will be appreciated ..thanks yall....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fired Honda »</TD></TR><TR><TD CLASS="quote">HI...Guys/Gals...
you can run upto 22lbs of boost with 440 injectors, and FMU, and an Apexi afc. get the afc and tune it youll be fine
</TD></TR></TABLE>you can run upto 22lbs of boost with 440 injectors, and FMU, and an Apexi afc. get the afc and tune it youll be fine
Fired Honda
May 23, 2003 12:05 AM
red civic standard
Oct 10, 2002 07:47 AM
