CEL 54. What is it??? [on a p72 OBD2 ECU]
Old May 22, 2003 | 11:09 PM
ShowSpeed's Avatar
Default CEL 54. What is it??? [on a p72 OBD2 ECU]
okay.. tried the serach function. Came up empty.
Any one knw what CEL 54 is?
Man
Old May 23, 2003 | 03:32 AM
tub_sephiroth's Avatar
Default Re: CEL 54. What is it??? [on a p72 OBD2 ECU] (ShowSpeed)
Crankshaft Speed Fluctuation (CFK) sensor.
Old May 23, 2003 | 08:22 AM
ShowSpeed's Avatar
Default Re: CEL 54. What is it??? [on a p72 OBD2 ECU] (tub_sephiroth)
thanks buddy.
But what does it mean?? My car spudders at 4000-5000 rpm.. it sounds like it's not going.. but once it makes it above the 4000-5000rpm.. it's okay again.
Man
Old May 23, 2003 | 08:32 AM
dohc-nyne's Avatar
it sputters cause its in limp mode....
Old May 23, 2003 | 02:39 PM
Default Re: (dohc-nyne)
This is what it says in the Helms:
The diagnostic system has a pulser rotor on the crankshaft and a pulse pick-up sensor on the engine block. The ECM monitors the crankshaft speed fluctuation based on the CKF sensor signal, and judges that an engine misfire occurred if the fluctuation goes beyond a predetermined limit.
Old May 23, 2003 | 05:11 PM
ShowSpeed's Avatar
Default Re: (tub_sephiroth)
ahh.. ok. gotcha.
I hooked up the P72 OBD2 ECU to a 99 honda prelude. Just wondering what the effects would be. Ran it down the street.. CEL came on.. came back home.
Man
Old May 23, 2003 | 05:26 PM
DK4200's Avatar
Default Re: (ShowSpeed)
check the conector first make sure it didn't come loose. Im not sure where it is on your engine but on my b18b1 it is right behind the crank pulley
EvilGSR1
Apr 17, 2014 02:32 AM
drycreekgsr
Aug 25, 2006 08:47 PM
nutsack
Oct 27, 2003 02:07 PM
