white smoke out tail pipes when racing...
Old May 22, 2003 | 07:39 PM
xstalkrx's Avatar
Default white smoke out tail pipes when racing...
According to bystanders...there were clouds of white smoke that would come from my tailpipe during a race. Someone told me that perhaps it was because i was running lean at higer RPMs. But I run premium fuel on a near stock motor, so how could this be the problem? Please flame me if I have no idea what it is to be running "lean".
Old May 22, 2003 | 10:30 PM
shadowdawn's Avatar
Default Re: white smoke out tail pipes when racing... (xstalkrx)
Running lean means too much air and not enough fuel, that kind of condition will kill your motor VERY fast...
List your exact setup.
Old May 23, 2003 | 11:46 AM
majeed11's Avatar
well.. it would help to mention what year and motor is in your car
Old May 23, 2003 | 11:47 AM
majeed11's Avatar
white smoke occures usually when you are burning coolant.
Old May 23, 2003 | 11:53 AM
WiggiE's Avatar
New User
Default Re: (majeed11)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by majeed11 &raquo;</TD></TR><TR><TD CLASS="quote">white smoke occures usually when you are burning coolant.</TD></TR></TABLE>
Old May 23, 2003 | 12:31 PM
xstalkrx's Avatar
Default Re: white smoke out tail pipes when racing... (shadowdawn)
Its a 90 ls with 132xxx miles. Nothing on it except for cold air intake and exhaust.
Old May 23, 2003 | 12:39 PM
WiggiE's Avatar
New User
Check your radiator for oil in it. It floats on top of coolant so, you will see it.
Old May 23, 2003 | 01:18 PM
xstalkrx's Avatar
Default Re: white smoke out tail pipes when racing... (WiggiE)
how does oil get into the radiator?
Old May 23, 2003 | 01:55 PM
WiggiE's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xstalkrx &raquo;</TD></TR><TR><TD CLASS="quote">how does oil get into the radiator?</TD></TR></TABLE>
BHG
Edit: I forgot not everyone knows the acronyms. BHG = blown head gasket.
Old May 23, 2003 | 03:11 PM
tilt's Avatar
Might want to replace your pcv valve, although it should be a bluish puff of smoke.
Old May 24, 2003 | 09:10 AM
xstalkrx's Avatar
ok ill have that checked out. Another thing, I shouldnt be running lean with premium octane gas right? Flame me if higher octane has nothing to do with how rich or lean I am running.
Old May 24, 2003 | 10:08 AM
MartyMarGSR's Avatar
Default Re: white smoke out tail pipes when racing... (tilt)
i had the same problem.
here's a pic someone took of me at my last autocross last weekend.
I have a 95 GSR.
JRSC, 6psi running stock injectors, JR FMU, timing back to 7 degrees, kami 4-1, carsound, 2.5" piping & dynomax muffler.
at first i thought that was smoke from my tires cuz after the run, they were scalding hot to the touch almost since I did a really big burnout before each of my runs, and that was towards the end of my lap.
But my friends who were watching told me it was coming out of my exhaust, mainly going to around 3/4 throttle to WOT, to 3/4 blipping it around turns, but that on straightaways it wasnt making much noticable smoke at all, only on turns...
Old May 24, 2003 | 12:56 PM
AllmotorJunkie's Avatar
HeadGasket!
Old May 24, 2003 | 11:08 PM
xstalkrx's Avatar
ok....but the chance of me running lean is next to none with 93 octane right? Im not running anything FI or major horsepower gains.
Old May 24, 2003 | 11:10 PM
WiggiE's Avatar
New User
A higher octane has nothing to do with a lean or rich situation.
Old May 24, 2003 | 11:25 PM
xstalkrx's Avatar
What causes a lean or rich situation?
Old May 25, 2003 | 12:17 AM
jacobyb's Avatar
It is when you are putting a load on the engine, like racing, and you are not getting enough fuel. That can be caused by a clogging fuel filter, a bad injector, a fuel pump that is getting ready to go. But the first thing I would do is just check your oil. If the oil ont eh dipstick is milky colored, you have a blown headgasket and that is the problem. The only problem with that theory is that normally if you have a blown head gasket, it will smoke no matter what RPM or load you are placing on the engine. When was the last time you had the fuel filter changed?
Old May 25, 2003 | 02:27 AM
svtec's Avatar
L D E S
Default Re: white smoke out tail pipes when racing... (jacobyb)
i would do a compression check just to be safe.
Old May 25, 2003 | 08:12 AM
Stewie's Avatar
Default Re: white smoke out tail pipes when racing... (svtec)
Burning synthetic oil will make white smoke.
Old May 25, 2003 | 06:14 PM
batman21's Avatar
Default Re: white smoke out tail pipes when racing... (Mac8008)
i have the same exact problem, when my car is running at high rpm's it leave a cloud of smoke behind. i have a 92 ls, then engine is stock but it is not the original motor.
powwie
Apr 20, 2006 08:58 PM
HBK_DAVIDDD
Jul 28, 2005 11:07 PM
CRX_Control
Nov 10, 2004 09:29 PM
davejj40
Sep 30, 2004 12:36 PM
SIK IN DA HED
Jan 6, 2004 09:24 AM
