abs light on for some reason
abs light is on for some weird reason, and the only thing that has jus been changed is timing belt...n/e connections there? help please...acura said they will look for $100 but i am not gonna pay that much for someone to "look into it"...thanx in advance!
-scott
-scott
Pull the code at the service connector to see what the problem is. Also, check you abs fluid reservoir to see if you have enough brake fluid in it.
newhondaowner29
Jan 11, 2006 08:11 PM
