Tial WG bolts striping
Old May 22, 2003 | 06:05 PM
Cramerox's Avatar
Default Tial WG bolts striping
So I had a problem with my wg leaking...i noticed that the bolts that came with the wg was stripping...maybe causing the leak at the manifold flange.
Do you guys know if i can order new Tial bolts...or you think i should just get some other bolts?
Old May 22, 2003 | 10:08 PM
JMinSi2000's Avatar
Default Re: Tial WG bolts striping (Cramerox)
I used studs. Go to Autozone and check out the help section...get a set of metric water pump studs. It should come with three studs and they are M8x1.25. I used these for my wastegate and on the head for the exhaust manifold.
Old May 23, 2003 | 09:16 AM
Cramerox's Avatar
Default Re: Tial WG bolts striping (JMinSi2000)
Ill check them out.....i just wanted to see since it get really hot there and probably causing the threads to stretch.
anyone else prefer the tial bolts?
Old May 23, 2003 | 11:37 AM
Tofurky's Avatar
i had some problems with the tial bolts too. I just used some high grade bolts.... so i can finaly use a wrench to tighten..
Old May 23, 2003 | 11:45 AM
BROOD's Avatar
Default Re: Tial WG bolts striping (Ruckus138)
8mm automotive studs always works pretty well for me with no stripping problems.
Old May 23, 2003 | 11:50 AM
Cramerox's Avatar
Default Re: Tial WG bolts striping (SLPR)
i was just about to ask that.....do you think the tap for the bolt is standard? im using a maxrev mani...well i guess as long as the bolt is the same as the tial right?
integlspwr2k
Sep 13, 2006 07:31 PM
greenGS
Dec 20, 2004 09:10 AM
93dx--hatch
May 7, 2004 07:24 AM
integranator
Sep 9, 2003 08:30 AM
