Hondata in an auto.
Old May 22, 2003 | 04:59 PM
noslude93's Avatar
Default Hondata in an auto.
I just bought a hondata system for a HT member.
It is a P28 ecu with stage 2
I have a 92 prelude SI with 4WS and an Auto. H23
Can they configure that to run none vtec when I get it tuned?
ALso My drive 4 light flashes. Is this going to work ?
If this is not going to work I have a P06 ECU also. But need to know before I take it 6 hours away to get it tuned.
Thank you
Old May 22, 2003 | 05:02 PM
KoRE's Avatar
Default Re: Hondata in an auto. (noslude93)
check hondata.com
the stages should work with autos.... not sure thoguh
Old May 22, 2003 | 05:07 PM
noslude93's Avatar
Default Re: Hondata in an auto. (KoRE)
P28 and P06 are both on my list but. Just want to know if any one knows why the D4 flashes. Also If they can configure it when I get it tuned.?
Hondata site really dont say much .
Old May 22, 2003 | 05:11 PM
KoRE's Avatar
call and ask that's a sure way to get the right answer...
Old May 22, 2003 | 11:25 PM
PUREVIL's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KoRE &raquo;</TD></TR><TR><TD CLASS="quote">call and ask that's a sure way to get the right answer...
he doesnt get long distance on his phone..
he was looking for an online answer for anyone who knows..
Im surpized that NOT to many peeps know there info on hondata..
I just ordered mine.... I know not to come here for info thats for sure ha ha..
Old May 22, 2003 | 11:58 PM
b19coupe's Avatar
Your D4 light is flashing because you have a tranny code in your ECU. 9 times out of ten, it is a speed sensor related problem. If your speedo works, short the SCS connector and read the code.
Old May 23, 2003 | 12:14 AM
Type Wah's Avatar
Default Re: Hondata in an auto. (b19coupe)
My d4 is blinking also
Old May 23, 2003 | 04:12 AM
noslude93's Avatar
Default Re: Hondata in an auto. (Type Wah)
What is the scs connector?
Will the code be in a manual? Thanks alot for the help.
Old May 23, 2003 | 05:16 AM
b19coupe's Avatar
The SCS connector is the two pin connector behind the glove box, you short it and the check engine light will stay on steady if there are no codes, and blink if there are any trouble codes stored in memory. The D4 light will also blink codes, if there are any tranny codes stored. Code #17 on the CEL is the speed sensor. I don't remember of the top of my head what code the D4 light will give you for the speed sensor. Pull the codes and use the chart in the manual to see what circuit is the problem, or post them, and I am sure that someone will be able to look them up for you. Then you will know what components to look at.
Old May 23, 2003 | 06:19 AM
KoRE's Avatar
Default Re: Hondata in an auto. (DRAG4ACCORD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DRAG4ACCORD &raquo;</TD></TR><TR><TD CLASS="quote">
Well if he went to the website it says . It is recommended to use the s200 rather than the Stage 2/3/4 system unless the ECU requires the use of the Stage 2/3/4 system (PR3, PW0 or automatic ECUs).
so it should work on an auto, but i'm not gonna say yea it will unless i know for sure, and the only way to know for sure is to call hondata and ask. or don't ahve long distance e-mail them.
Old May 23, 2003 | 06:47 AM
len's Avatar
len
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b19coupe &raquo;</TD></TR><TR><TD CLASS="quote">The SCS connector is the two pin connector behind the glove box, you short it and the check engine light will stay on steady if there are no codes, and blink if there are any trouble codes stored in memory. The D4 light will also blink codes, if there are any tranny codes stored. Code #17 on the CEL is the speed sensor. I don't remember of the top of my head what code the D4 light will give you for the speed sensor. Pull the codes and use the chart in the manual to see what circuit is the problem, or post them, and I am sure that someone will be able to look them up for you. Then you will know what components to look at.</TD></TR></TABLE>
Very good information. On Most Automatic Hondas, if the D4 light is blinking, check the speed sensor. 92-95 Legends are notorious for having the electronic sensor replaced. There is a chance that that year Honda Prelude shares the same sensor or something similar.
Old May 23, 2003 | 09:02 AM
noslude93's Avatar
Default Re: Hondata in an auto. (len)
Thank you I will check the code when I get off work tonight. Then I will let you know what I find out .
Is it just that the speed sensor wont work with that ecu or what ?
Because I have never had a problem like that before?
Thanks
Old May 23, 2003 | 03:48 PM
noslude93's Avatar
Here is what I have, the ecu throughs 22 .
The drive light throughs 8 14 1 2 . If you read them the same as cel.
Any thoughts.
thank you
Old May 23, 2003 | 05:40 PM
noslude93's Avatar
Any one know how to find out what the Tranny codes are ?
Old May 23, 2003 | 05:46 PM
b19coupe's Avatar
ECU code #22 is for the VTEC pressure valve. I am not at work, so I can't look up tranny codes right now. I have the ECU codes stored on my hard drive.
Old May 23, 2003 | 06:33 PM
noslude93's Avatar
If you could look up the tranny codes that would be great .
Thanks
Old May 23, 2003 | 11:56 PM
sgT's Avatar
sgT
is the ecu auto?
Old May 24, 2003 | 10:06 AM
noslude93's Avatar
Default Re: Hondata in an auto. (sgT)
no its a manual ecu.
Old May 24, 2003 | 12:42 PM
b19coupe's Avatar
A manual ECU and an Automatic transmission?
Old May 24, 2003 | 01:06 PM
noslude93's Avatar
Yes teh guy that sold it to me said it would work .?
I dont know what I need to do.ha ha
Old May 24, 2003 | 09:42 PM
noslude93's Avatar
bump
h23prelude
Mar 16, 2008 10:15 AM
no1knows908
Jul 21, 2007 06:54 PM
teg01type-r
Jan 3, 2007 03:20 AM
Big Teggie
Jun 23, 2003 05:41 PM
noslude93
May 22, 2003 05:54 PM
