How to take out backseat in 95 ls.....
Just need a link of a quick explanation.... I just dont want to tear anything up...it looks like just a pin holding down the bench and im not sure about the backrest.... thanks guys
Should be the same as my Civic.
2 clips one either side of the back rest. By the plastic interior panels, little black clips. Pop them off and you can push the back rests towards the interior panels and then pull them out.
Should be one 10mm bolt holding the *** pad in place. 2 clips at the front, lift the seat up and wiggle it out.
Your back seats are removed.
check the articles at team-integra.net
from what i remember, on hatchbacks, the rear panels have to be removed to access those clips which remove the back part of the seat, then there is a bolt which holds the bottom part down.
I got the backs off... but ive lost too much sunlight to do the bottoms
I can tell there are two clips on the bottom of the "*** pads". Thanks guys!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pHizerDC4 »</TD></TR><TR><TD CLASS="quote">I got the backs off... but ive lost too much sunlight to do the bottoms
I can tell there are two clips on the bottom of the "*** pads". Thanks guys!</TD></TR></TABLE>
The rest is easy, just unbolt the 10mm bolt at the rear of the bottom cushion, then lift and pull back. The two "latches" in the front aren't bolted down...they just slide into these notches.
I can tell there are two clips on the bottom of the "*** pads". Thanks guys!</TD></TR></TABLE>The rest is easy, just unbolt the 10mm bolt at the rear of the bottom cushion, then lift and pull back. The two "latches" in the front aren't bolted down...they just slide into these notches.
mikeoxlodge
Jul 29, 2008 09:26 PM
bigBOI_92DA9
May 31, 2004 02:20 PM
