injectors and turbo
Old May 22, 2003 | 04:20 PM
turbob18a1's Avatar
Default injectors and turbo
i need to know if anyone has ever literally bolted a turbo on a stock integ ls
please reply
i'm trying to decide if i still want turbo or just to sell it all and build n/a
Old May 22, 2003 | 04:26 PM
KooK's Avatar
Mustang Sally
Default Re: injectors and turbo (turbob18a1)
How large are the injectors? Do you know? I have no clue about LS injectors.
Old May 22, 2003 | 04:46 PM
turbob18a1's Avatar
i think 240cc i'll go with 440cc
Old May 22, 2003 | 04:53 PM
joe_bocc's Avatar
Default Re: (turbob18a1)
You can bolt a turbo on and run the stock injectors to a point. Running 8~9 psi you would probably be fine with the stock 240 cc/min injectors.
Unless you're running like 20 psi boost, 440 would be over kill unless you have a Hondata.
Old May 22, 2003 | 05:00 PM
turbob18a1's Avatar
Default Re: (joe_bocc)
i was planning on getting hondata with boost capability , here is what i was thinking.. if a bolt on turbo for an LS will only give me around 220-240 hp and bullfrog performance can build a top end package,that it alone will almost put me to 210 then which is better the more research i do , the more options i find. its hard to decide any input would be nice. i'm not trying to be different i just want speed.
Old May 22, 2003 | 05:03 PM
joe_bocc's Avatar
What does this Bullfrog head package include?
Old May 22, 2003 | 05:13 PM
turbob18a1's Avatar
port polish head,intake manifold,throttlebody,and a set of race grind cams.
they are high but my best friend has a 94 rs with the head pack, pulleys, int, header and thats it and his gtech is reading 223 hp
Old May 22, 2003 | 05:18 PM
joe_bocc's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbob18a1 &raquo;</TD></TR><TR><TD CLASS="quote">port polish head,intake manifold,throttlebody,and a set of race grind cams. they are high but my best friend has a 94 rs with the head pack, pulleys, int, header and thats it and his gtech is reading 223 hp</TD></TR></TABLE>
I don't know anything about Bullfrog but that kit sounds pretty well rounded. I have my doubts about this package getting you 210 hp without boost. To get 210 hp on an LS, the kit would have to gain 70 hp which I don't see happening without turbo. Combine that package with a mild turbo kit and you'll have a pretty nice set-up.
Old May 22, 2003 | 05:22 PM
turbob18a1's Avatar
thats what i was thinking but dude i've been patient knowing someone else would make the mistakes .i don't want to waste $6,000. so you think that combo would kick ***
g0tgot
Sep 17, 2008 12:33 PM
B18 rider
Aug 8, 2008 10:51 AM
dragsol
Oct 16, 2002 07:35 PM
