oil pan leak!?
Old May 22, 2003 | 02:15 PM
hollaback6's Avatar
Default oil pan leak!?
okay guys i am already pissed off with this crap. i have tried sealing my oil pan 4 times since i turboed my car. First i reused that stock gasket it didn't work. Then i used a brand new oem rubber gasket and rtv silicone, then right stuff, then i used right stuff with a brand new oil pan and it still is not sealed. 2 bolts have been broken and it is leaking on the complete other side from where they are broken. i think they might be overtightened cuz i don't have a torque wrench. If anybody has any ideas that can help me out please tell.
Old May 23, 2003 | 04:24 AM
JimBlake's Avatar
Default Re: oil pan leak!? (hollaback6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hollaback6 &raquo;</TD></TR><TR><TD CLASS="quote">... i think they might be overtightened cuz i don't have a torque wrench. If anybody has any ideas that can help me out please tell.</TD></TR></TABLE>
Here's an idea - get a torque wrench. They're really useful. Rubber gaskets squirm around & leak when they're overtightened.
Well, fix the broken bolts, too.
Old May 23, 2003 | 02:28 PM
hollaback6's Avatar
umm...i am trying to fix the broken bolts but it is not as easy as it sounds.
Old May 23, 2003 | 02:43 PM
Turbo Powa's Avatar
Take a small drill and tap into the broken bolts. If anything get a book that tells you how to repair broken bolts. Its not that hard, just time consuming. Get two new bolts for the oil pan an your set.
Old May 23, 2003 | 03:15 PM
AK94GSR's Avatar
Default Re: oil pan leak!? (Panda EK)
I would definitely recommend a torque wrench since making sure the bolts are torqued right makes all the difference. especially with the ruber gasket. gotta replace mine soon aswell cause i have a small barely little leak, but i just want to replace it since its probably just gettin old
san_luis
Mar 22, 2010 10:09 AM
Civic Racer X 7
May 23, 2007 12:42 PM
Rhood
Feb 7, 2007 05:30 PM
Si Shane
10
Dec 13, 2004 05:35 PM
htownteg
Oct 27, 2003 04:28 PM
