radiator cap?
Old Jul 12, 2001 | 12:43 PM
SiR-G96's Avatar
Default radiator cap?
I'm changing my radiator cap to higher pressure, what kind of pressure should i use on a drag3 gs-r with fluidyne radiator? Do i need to change the thermostate too?
Thank You!
Old Jul 12, 2001 | 12:44 PM
b18bturbo's Avatar
Default Re: radiator cap? (SiR-G96)
use factory honda thermostat but drill some small holes around it. second thing you need is approx 25psi stant radiator cap will work fine.
Old Jul 13, 2001 | 06:59 AM
SiR-G96's Avatar
Default Re: radiator cap? (b18bturbo)
Is 25psi around 1.7kg/cm2? Do you know what company makes one like that? most caps i seen are around 1.35kg/cm2 and the euro R cap is 1.38kg/cm2, will 1.7 be better or just go with the R cap?
Old Jul 13, 2001 | 07:14 AM
b18bturbo's Avatar
just go to performance store and get a STANT high peroforance radiator cap. Should cost you no more that 15 bucks. any v8 store has it.
Old Jul 13, 2001 | 07:30 AM
SiR-G96's Avatar
Cool, thank you so much!
Sorry I have 1 last question, if i put too much holes on the bumper and cool down the radiator too much, will that cause problem to the radiator or engine?
"My radiator died the next day after i made 3 huge holes on my bumper"
Old Jul 13, 2001 | 12:41 PM
Liltrix's Avatar
Why not call up fluidyne and hear what they advise? they might know a little better thatn we do.
Khmi
Sep 19, 2008 05:43 AM
