What Tool do I use to drill a hole for Knock Sensor??
What tool is needed to drill into the block to make threads for the knock Sensor?? If I'm using a p28 Ecu with hondata, will i need a knock sensor?? The motor on hand is a B20/vtec
P28's don't look for a knock sensor, but to answer your question you'd want to use a 10.9 mm drill bit to first open up the hole a bit, then use a 12mm x 1.25mm thread pitch tap to thread the hole for the knock sensor Make sure to take your time and use alot of lubricant (I just use oil) when tapping a hole.
i thought the B20's already had a knock sensor...oh well..
this is where they put their knock sensor....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RedlinedVTEC »</TD></TR><TR><TD CLASS="quote">P28's don't look for a knock sensor, but to answer your question you'd want to use a 10.9 mm drill bit to first open up the hole a bit, then use a 12mm x 1.25mm thread pitch tap to thread the hole for the knock sensor Make sure to take your time and use alot of lubricant (I just use oil) when tapping a hole.</TD></TR></TABLE>
or you could take a 17mm head nut (from mount, etc) and have someone WELD it to the head of a 14mm bolt. then just screw the knock sensor into the inner hole on the upper alt mount like shown above. No drilling or tapping needed. EASY FIX
rice is nice
Feb 23, 2009 08:21 AM
Leviata-N
Mar 13, 2006 11:36 AM
Team 4
Aug 4, 2004 04:53 PM
