Track Alignment Quetions
Old May 22, 2003 | 09:18 AM
pcorad's Avatar
Default Track Alignment Quetions
I went to my tire shop for a track alignment this morning. The specs I gave them were: 1/8" total toe in front; 0" toe in the rear.
Their laser machine reads in degrees (which we figured out converts to inches: 1/8" = .12 degrees = .12"). We got the fronts set to .06 on each side, so .12 total (or 1/8" total).
The rear specs left me scratching my head. The specified range is .04 - .16 degrees. According to his machine (I was sitting in the car and couldn't see) he set the rears "pointing straight ahead". On the printout it says the rears are +.11 degrees on both sides.
To get 0 toe in the rear, shouldn't the print out read .0 degrees on each side?
Any insights would be welcome.
Paul: who wishes he had his own garage, so that he could do his own alignments...
Old May 22, 2003 | 09:20 AM
RTW DC2R's Avatar
Default Re: Track Alignment Quetions (pcorad)
Did you ask the alignment d00d? I would think that it should show 0 for the rear but Im not an alignment d00d.
Old May 22, 2003 | 09:23 AM
Asahi's Avatar
YOur " to degree conversion is hat I came up with last weekend when i had my car aligned. Also ero is zero your car should say zero at each wheel if that was the goal. What did he use to judge straight ahead? the machine or his eyes?
Old May 22, 2003 | 11:33 AM
Big Phat R's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pcorad &raquo;</TD></TR><TR><TD CLASS="quote">To get 0 toe in the rear, shouldn't the print out read .0 degrees on each side?</TD></TR></TABLE>
Yes - you would think so. It looks like you have toe-in at the rear too. I assume all your readings are "+".
You only used "+" for your rear measurement in your post.
Old May 22, 2003 | 11:45 AM
pcorad's Avatar
Default Re: Track Alignment Quetions (Big Phat R)
The alignment dood wasn't too helpful. For your basic alignment, he punches in the make/model/year, and the screen presents 4 idiot proof "gauges", one gauge for each tire, and he just needs to center a line on each of the "gauges".
I asked him about the rear measurements...but his communication skills weren't great. The shop, in general, is great; so I can go back and have this fixed w/o a hassle.
Anyways, values for the rear on the print out are both +.11. Does this imply that the rear is toe-d in? Or toe'd out?
Old May 22, 2003 | 11:49 AM
Asahi's Avatar
As BPR alliuded to + should mean toe in (if I am remmebering right).
Old May 22, 2003 | 03:11 PM
Ausmith's Avatar
Just curious why you are running toe-in? Having trouble with straight line stability?
Old May 22, 2003 | 05:29 PM
1GreyTeg's Avatar
Default Re: Track Alignment Quetions (Ausmith)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ausmith &raquo;</TD></TR><TR><TD CLASS="quote">Just curious why you are running toe-in? Having trouble with straight line stability?</TD></TR></TABLE>
Geez yeah, I run an 8th toe out... Makes for nice quick response...
Yep.
A. who watched recently very closely as rodney got his custom laser alignement done last week by a very reputible shop.
Old May 23, 2003 | 05:48 AM
pcorad's Avatar
Default Re: Track Alignment Quetions (1GreyTeg)
So I went back to the tire shop this AM. The alignment dood and I looked at his alignment screen which had a graph that shows the rear specs to be .04 to .16.
I could not convince him that setting the alignment to .0 would point the rear tires straight ahead. I even had him break out a tape measurer with me and do some measurements across the rear tires that showed the rears toed in about 1/8". He still couldn't agree... He's the kind of guy that believes the machine because he doesn't understand math.
Whatever. We set the rears to read .0 degrees. And the front's to read .06 on each side. Done.
Old May 24, 2003 | 07:28 PM
99MR_SiR's Avatar
Take it to another place and get it checked or you'll never know if you cheated yourself, it's worth the extra $$ for peace of mind.......
Old May 24, 2003 | 08:33 PM
SPiFF's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pcorad &raquo;</TD></TR><TR><TD CLASS="quote"> He's the kind of guy that believes the machine because he doesn't understand math.</TD></TR></TABLE>
Sounds like your avg service station employee. When it comes to race cars, I either take mine to a place used to dealing with them or a shop which will let me hang out in the garage and "help" out the techs.
Libertariat
Suspension & Brakes
23
Dec 17, 2010 08:51 AM
AzntaggeR
18
May 1, 2004 03:21 AM
pcorad
May 22, 2003 09:21 AM
Reid
Jul 5, 2002 01:24 PM
albert butterbikini
Jan 29, 2002 05:48 PM
