95 gsr ignition problems...........
Old May 22, 2003 | 07:16 AM
95GS-Racin's Avatar
Default 95 gsr ignition problems...........
Alright, well the other day when I went to start my car it turned over but it wasnt actually starting. I got it to start after a couple attempts. The car seems to just stop revving and boggs hard as hell if I try to drive fast. But sometimes this happens when I m just driving normal. Sometimes it doesnt happen at all. Could this problem be the dizzy? Oh yea BTW every single time the car did this the check engine light would come on for a second but it would then turn back off. Can I check the CEL code or does it have to stay on the do so? Thanks ahead of time H Techers!
Old May 22, 2003 | 08:22 AM
JimBlake's Avatar
Default Re: 95 gsr ignition problems........... (95GS-Racin)
It's supposed to store the codes, so you can read them even if the problem is intermittent.
Just go ahead & try to read the codes. The worst that can happen is there's nothing stored...
Old May 22, 2003 | 09:31 AM
95GS-Racin's Avatar
Default Re: 95 gsr ignition problems........... (JimBlake)
Problem solved> I checked my fuses under the hood and found the ecu fuse was like half way in. I pushed it down all the way and now it hasnt given me any trouble. Thanks for your help.
Old May 22, 2003 | 09:59 AM
DrunkNRacer's Avatar
thats what happens when you store weed in it.. lol..
Old May 22, 2003 | 10:00 AM
1_bad_EF's Avatar
Default Re: 95 gsr ignition problems........... (G-villeRacer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by G-villeRacer &raquo;</TD></TR><TR><TD CLASS="quote">thats what happens when you store weed in it.. lol..</TD></TR></TABLE>
no no no its the fuse box under the <U>dash</U>
Old May 22, 2003 | 01:25 PM
Default Re: 95 gsr ignition problems........... (1_bad_EF)
look up and observe [[ I checked my fuses under the hood ]] yes yes yes.. the <U>HOOD!</U>
94teggiels
Feb 11, 2009 10:35 AM
slowem1si
Jan 11, 2009 10:24 AM
JThrasher79
Dec 29, 2005 02:28 AM
BOOSTEDgreeneg
Sep 15, 2005 07:27 PM
