VTEC Engagement Problem
Old May 22, 2003 | 03:55 AM
Yellow Submarine's Avatar
Default VTEC Engagement Problem
Hi Guys,
The VTEC on my R has been sporadically engaging and disengaging after 6000 RPM on the tach. It is always in the low gears. Usually, it engages at about 7000 and drops off at 7500, and that is all. Sometimes it engages at 6000, drops at 7000, and reengages at 7500. I have a stock R with 104K on it, and the car is due for a timing belt and tune up, which I will be doing this weekend to hopefully solve the problem. Should I adjust the valves as well? Any help would be appreciated.
Old May 22, 2003 | 04:26 AM
Default Re: VTEC Engagement Problem (zyg)
Oil was way low! Off to the store with me! Thanks!
Old May 22, 2003 | 07:35 AM
Mires's Avatar
Default Re: VTEC Engagement Problem (Yellow Submarine)
Mine is doing the same thing but I am also a little past my oil change so at lunch I am going to change my oil.
VTECROAR96typeR
May 19, 2009 02:55 AM
Pleiadi79
Jun 12, 2008 08:22 AM
LeidenK
Jan 17, 2007 04:44 PM
green_beret
Sep 16, 2006 05:10 AM
hdsi94
Aug 23, 2006 03:53 PM
