Test Pipe on 89 Crx Si???
Old May 22, 2003 | 03:12 AM
Red_Si's Avatar
Default Test Pipe on 89 Crx Si???
I was about to go get one today and was wondering if it will make a difference in power??? Will i feel the boost in power? oh, btw i'm also getting a cat-back at the same time. let me know
Old May 22, 2003 | 03:15 AM
Charlie Moua's Avatar
Default Re: Test Pipe on 89 Crx Si??? (Red_Si)
it will be alot louder with a testpipe and full exhust system. you should instantly feel more power (2-5hp)
Old May 22, 2003 | 06:10 AM
DJ_SaNdOz's Avatar
you should see an inprovment in top end for sure- the climb to redline should happen faster
Old May 22, 2003 | 06:24 AM
Vinceg99's Avatar
Default Re: Test Pipe on 89 Crx Si??? (DJ_SaNdOz)
Well considering that your doing both at the same time yes you will notice an increase in power now if you already had a cat back and you added a test pipe I think it would add very little but not enough for you to notice. I would assume that it would be the same if you have a stock exhaust and just added a test pipe as well.
Old May 22, 2003 | 07:38 AM
therealciviczc's Avatar
I think my Si lost power with the test pipe and a non resonated Thermal Exhaust... I went back to the CAT. The car felt like it had zero torque and only made more noise at the top end.
I recommend saving your money.
Now with a turbocharged car.... that is a different story.
EG type GTR
Jul 9, 2006 05:28 PM
smash fascism
23
May 26, 2005 07:26 AM
GSRerrr
Jan 2, 2005 12:27 AM
SMC Integra
May 19, 2004 06:01 PM
Token Blk Guy
Sep 29, 2002 09:53 PM
