gas/exhaust smell when AC is on:help:
I cant tell where its coming from, but i definitely get a bad gas/exhaust smell coming in with the ac on. Anyone here have this problem? Help...
do you still get it with the Recirculation button on?
sounds like you have an exhaust leak. park, engine running, pop the hood, put your face above intake manifold and get a good whiff.
dont get the smell with recirculation. Ive tried smelling around different areas of the engine bay with the car on, but i havent been able to pick up the smell. Ill try checking around the intake mani.
would a bad catalytic converter cause a stench to come up through the AC?
yeah, if u had an exhaust leak you'de be able to smell it.
retighten your fmu connections. I had them come loose on me and the fmu was spraying fuel all over the place when I boosted.
had a slight smell coming from the fmu, so i tightened all the lines. I definitely had a fuel leak from the line on the second fuel pump, fixed that. I still have a smell coming in. So the search continues
DCSportEJ1Civic
14
Dec 24, 2007 12:29 PM
bhaz413
Aug 13, 2002 05:05 AM
