removing splash gaurd?
Old May 21, 2003 | 10:03 PM
KingJeff's Avatar
Default removing splash gaurd?
Theres a flap under the bottom front part of my car . I think its the splash gaurd. Well anyways, mine is curved downwords and is close to the ground. How do I remove it? Is the splash gaurd connected to the front lip?
Old May 21, 2003 | 10:31 PM
HKJ's Avatar
HKJ
Default Re: removing splash gaurd? (Jeff K.)
jack up your car, there should be 4 or 6 10mm bolts in there, just take them off.
Old May 21, 2003 | 10:35 PM
integobsession's Avatar
Default Re: removing splash gaurd? (HKJ)
The splash guards are actually held on by self-tapping screws I believe. And if you're talking about the front splash guards... then you don't have to jack up the car... just steer ur rims so you can get to the splash guards with the screw driver.
Old May 21, 2003 | 11:24 PM
KingJeff's Avatar
Default Re: removing splash gaurd? (integobsession)
nooo im not talking about the mud gaurds. IM talking about a piece of plastic underneath the car itself. ITs kind of hard to explain.
Old May 21, 2003 | 11:44 PM
B2FiNiTY's Avatar
4 10mm bolts and the rest are plastic clips/screws. Should be 6 total.
I would keep it because it protects the radiator and others.
Old May 21, 2003 | 11:46 PM
xteg95's Avatar
Default Re: removing splash gaurd? (B2FiNiTY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2FiNiTY &raquo;</TD></TR><TR><TD CLASS="quote">4 10mm bolts and the rest are plastic clips/screws. Should be 6 total.
I would keep it because it protects the radiator and others. </TD></TR></TABLE>
Mine was the same way, I just put some zip ties to hold it up.
Old May 21, 2003 | 11:56 PM
KingJeff's Avatar
Default Re: removing splash gaurd? (xintegra01)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xintegra01 &raquo;</TD></TR><TR><TD CLASS="quote">
Mine was the same way, I just put some zip ties to hold it up. </TD></TR></TABLE>
kool. but do u guys know if that piece is connected to the lip and the bumper??
Old May 22, 2003 | 05:51 AM
stevieteg's Avatar
mine was the same way. There are bolts that hold it from sagging, but they are too small. I bought really big washers so the bolts would not slip through again.
Old May 22, 2003 | 06:31 AM
ArizSun21's Avatar
From: Do I look like Michael Bolton from Office Space,, MD, USA
Default Re: (stevieteg)
If you have an AEM CAI please don't take the flap off!!! I took mine off my old civic and hydrolocked the motor during a rainstorm. But I got an LS motor out of it!
Old May 28, 2003 | 08:40 AM
KingJeff's Avatar
I went to acura and they didnt have the bolts. The bolts they have me wouldnt fit. They are suppose to be plastic clips with a screw on top right?
Old May 28, 2003 | 08:44 AM
P1mpSlap's Avatar
Dremel
I had to remove mine. It was all fubar and what not. Was scraping the ground b/c the previous owner of my car fucked it all up.
Old May 28, 2003 | 08:46 AM
10K2HVN's Avatar
Default Re: (P1mpSlap)
zip ties own my front spash gaurd!
Old May 28, 2003 | 09:50 AM
KingJeff's Avatar
Default Re: (10K2HVN)
where do u zip tie it too?? I might just cut mine off with a dremel.
Old May 28, 2003 | 09:56 AM
Type Wah's Avatar
I ran mine over
Old May 28, 2003 | 10:18 AM
Volcom's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 10K2HVN &raquo;</TD></TR><TR><TD CLASS="quote">zip ties own my front spash gaurd! </TD></TR></TABLE>
same here, i used some very heavy duty ties and they won't ever break. They're like the spare handcuffs police officers use when they run out of real handcuffs. Thick plastic zip ties
Old May 28, 2003 | 10:50 AM
95 Gizzer
Guest
Posts: n/a
Yeah that took care of it
Old May 28, 2003 | 10:57 AM
IntEGNYC's Avatar
Default Re: (95 Gizzer)
Are you referring to the fender trim or the fender liner in the wheel well?
Old May 28, 2003 | 10:58 AM
KingJeff's Avatar
Default Re: (IntEGNYC)
im refering to the flap that is attached to the front bumper. It is right below the car.
Old May 28, 2003 | 11:14 AM
10K2HVN's Avatar
Default Re: (Jeff K.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jeff K. &raquo;</TD></TR><TR><TD CLASS="quote">where do u zip tie it too?? I might just cut mine off with a dremel. </TD></TR></TABLE>
sorry i didnt see you post til now!
Normally that flap is bolted to the underside of your car like this:
but a couple of dings later it tears..so what you do is take out those bolts and if their not bent then you can get some big washes and bolt everything back up or you can use the holes as a place to run your zip ties through!
Just run zip tie in the hole and around everthing to hold the flap to the top again!
Old May 28, 2003 | 12:12 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
I had mine ziptied for the longest time because those holes in my radiator support did not have any threads! Late I found out it was supposed to have that plastic connectors that expand when you push in the plastic screw in the middle. So I got a couple of those and used them along with washers and I've never had a problem since. The zipties used to always break every now and then.
Old May 28, 2003 | 12:53 PM
10K2HVN's Avatar
Default Re: (PatrickGSR94)
sucks for yoouu...mine hasnt yet..~1 year now....
Old May 28, 2003 | 01:26 PM
daewonder.'s Avatar
I had this problem too. I used a razor to cut off the passenger side half.
I was gonna take the whole thing off but the drivers side is protecting some belts. Too bad that side is hella sagging/scraping too now. I might just get a new piece from acura.
Old May 28, 2003 | 02:01 PM
VTECorona's Avatar
Default Re: (B18Chillin)
Over the winter i went in to an oil change place and was I was pulling out it caught onto the tracks and tore right throught the middle of it so its cut in half and each side dangles down. I tried to zip tie it but it wasn't holding it up much more than it was without the zip ties so I took them off. Is it ok to take the splash guard off or hard to find replacements?
Old May 28, 2003 | 02:51 PM
intekragsr's Avatar
Default Re: (97RedTegGSR)
lol I forgot to put all the screws in on mine, and it got blown off on the bridge and hit my girlfriends car behind me I thought I ran over a seagull or something
Old May 28, 2003 | 04:43 PM
Brian-Brian
Guest
Posts: n/a
my's does the saame thing too is it safe to remove???? do i need it????
