aww man this sucks...
Old May 21, 2003 | 09:27 PM
rasta420's Avatar
Default aww man this sucks...
theres a plastic piece on the radiator hose near the cap that i broke today - its connected to the pipe that runs to the coolant reservoir, located to the right of the radiator cap. it broke off when i was using a pry bar to get the head off
is this part replaceable? it doesnt look like it is, it looks like it was connected to the radiator. does this mean i have to get a new radiator? or what can i do to patch this up?????? thanks
Old May 21, 2003 | 09:31 PM
fearless_dsm's Avatar
Default Re: aww man this sucks... (rasta420)
try some jb weld.You have to make sure there is absolutely NO water around the area or it will never dry.Drain radiator first.When i took my crx to the track, the bushings in my crossmember were bad and the LS motor was too strong so the crossmember would jump forward and break my radiator.I had to keep adding jb weld after each run.
Old May 21, 2003 | 09:41 PM
rasta420's Avatar
Default Re: aww man this sucks... (fearless_dsm)
what is jb weld? where do i get it? does it require torching?
Old May 21, 2003 | 09:44 PM
allmtrSI's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rasta420 &raquo;</TD></TR><TR><TD CLASS="quote">what is jb weld? where do i get it? does it require torching?</TD></TR></TABLE>
you can get it at autozone or home depot, and no, it doesn't require torching.. just time to dry.
Old May 22, 2003 | 12:19 AM
FR-MOB: ThE bEe GuY's Avatar
Default Re: aww man this sucks... (allmtrSI)
I thought JB Weld only worked on metal?
Old May 22, 2003 | 02:27 AM
ThatRicerDaniel's Avatar
JB weld is good shieet .. works on everything if you just be patient and let it dry.
Old May 22, 2003 | 04:23 AM
civicwagonman's Avatar
Default Re: aww man this sucks... (NitrousDreamz)
permatex has soem epoxy weld that works better on plastic. we use it to fix motorcycle fairings. awesome stuff.
Old May 22, 2003 | 04:26 AM
WuShu's Avatar
New User
Default Re: aww man this sucks... (civicwagonman)
great stuff, its strong as hell.
Old May 22, 2003 | 07:40 AM
therealciviczc's Avatar
Make sure when you JB weld it you don't 'weld' the hole shut. Stick a screw or something in there when you put the JB on. Then take the screw out so you don't weld it in there too!
Old May 22, 2003 | 07:43 AM
Home Skillet's Avatar
Default Re: aww man this sucks... (WuShu)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WuShu &raquo;</TD></TR><TR><TD CLASS="quote">
great stuff, its strong as hell.</TD></TR></TABLE>
You are the JB Weld spokesperson.
dwn2earth922
Sep 12, 2009 10:00 AM
baustin909
Apr 21, 2008 10:16 PM
kellogg97rs
Apr 4, 2007 12:13 PM
ID_ten_T
Sep 1, 2004 08:13 AM
BluLuder
Jul 29, 2002 11:29 AM
