obd2 lude to obd1?
Old May 21, 2003 | 08:59 PM
black_sh's Avatar
Default obd2 lude to obd1?
i have a chipped p28 ecu and tried to install it in my 01 lude sh with an obd2-1 harness. the engine starts, but ends up dying. i'm pretty sure it's either that the harness is wired incorrectly or i need an obd1 distributor. can anyone help me with this and has anyone successfully done this on an obd2 lude?
Old May 22, 2003 | 01:47 PM
Behan's Avatar
Default Re: obd2 lude to obd1? (black_sh)
i don't know how to solve your problem, but if you want to sell the ecu let me know
Old May 22, 2003 | 02:34 PM
The Driver's Avatar
What year is the Prelude? If it's a 96 or up it is already OBD2.
It might be OBD2 even if it's a '95 (check for a sticker that says OBD2).
George
Old May 22, 2003 | 02:37 PM
kotetu's Avatar
Default Re: obd2 lude to obd1? (The Driver)
He is going the other way George. He's using an OBD1 ecu in his OBD2 Prelude SH.
I'm not certain, but the fact that you have an SH might have something to do with it. I think the SH's ecu works with the ATTS computer. I'm not really sure though.
Old May 23, 2003 | 07:44 AM
black_sh's Avatar
Default Re: obd2 lude to obd1? (kotetu)
with the searches i've done before.....i just know that i will lose atts and the immobilizer. other than that it should be fine. obdI's, teh timing can be adjusted manually while the obd2 you cannot do it with the distributor. i think i needed to advance my timing for it to stop stalling, but i could'nt do it manually. found out the hard way. well, i have hondata now and wonder if i could just somehow datalog the timing and not have to get an obd1 distributor and rewire. does anyone know whether i have to get the obd1 distributor or could i just manually do it with hondata?
Old May 23, 2003 | 07:45 AM
black_sh's Avatar
Default Re: obd2 lude to obd1? (93preludevtec)
93preludevtec, i'm gonna need the ecu for my hondata.
Modified by black_sh at 5:49 PM 5/23/2003
Old May 23, 2003 | 08:50 AM
black_sh's Avatar
anyone with a 5th gen running hondata?
Old May 23, 2003 | 11:12 AM
ludegirl1004's Avatar
Similar situation happened to me. Car was running weird. My mechanic said he thinks that somethin is wrong with the harness/clip.
Old May 23, 2003 | 03:16 PM
Firedrake's Avatar
Default Re: obd2 lude to obd1? (ludegirl1004)
My '96 is converted to OBD1 and Hondata and has no problems with the OBD2 Distributor (aka crank angle sensor is at the crank pulley instead of in the distributor)
Brian
Old May 23, 2003 | 05:29 PM
black_sh's Avatar
Default Re: obd2 lude to obd1? (Firedrake)
firedrake, jus wondering, did you ever try the obd1 ecu without the hondata before?
egbaby
Mar 1, 2008 06:52 AM
cparreno
Mar 10, 2007 10:08 AM
92civic_si
16
May 6, 2004 02:50 PM
beedoublejay
Aug 6, 2003 01:02 PM
